Old 08-29-2005, 04:09 AM   #1 (permalink)
Car: 91 civic sir b16a1
Mods: koni adj shocks, hr springs, zimmerman drilled rotors,ferodo brakepads,typer shiftknob floormats and decals,intake, powerchips ecu chip,removed cat,sparcopedals and omp front tie bar
ef9_b16a1 is an unknown quantity at this point
b16a block-pr3/pct pistons-gsr crank-WHAT ROD??
hi
i have a b16a block
1 gsr stock crank and 2 sets of pistons
pct b16b/pr3 stock b16a
i want to install the crank and make a pseudo stroker kit. 1797cm3
i believe i can use my pistons, either set, what rods will i need??
i believe custom right?
the crower b16a stroker rod will do??
since i have a gsr crank
b16a block
and pr3-pct pistons, can u inform me what rods i ll be needing??
thanks in advance for the reply
EE9_B16A EDM civic vtec 91 150 ps
HKS MEGA FLOW -HEAT INSULATED
CUSTOM CAT BACK EXAUST
CUSTOM JDM ECU CHIP-bre tuned
B16B CAMS-VALVE SPRINGS-RETAINERS
10.7C.R
GROUNDING KIT
KOSEI K1 RACING 14 INCH 4.3 KG RIMS
ADVAN A032R
STRUT BARS
HR SPORT SPRINGS
KONI SPORT YELLOW ADJ
GOODRIDGE BRAKE LINES
WWW.REDLINERS.GR
GREEKHONDACLUB
ef9_b16a1 is offline
Old 08-30-2005, 04:42 AM   #2 (permalink)
Leitner is an unknown quantity at this point
wont work. you have a short deck height block, a long stroke crank and standard compression height pistons. the rod will be real short and that will give you tramendous side loading because of the very bad rod/stroke ratio you will have. it will not last to long. just to put it in perspective, the crank has a 10mm longer stroke thena b16 so you are going to need a rod that is 5mm shorter than the b16 rod. if the stock gsr has a r/s of 1.6:1 then think how bad it will be if you reduce it another .200". it will be a custom rod for sure so your looking at $600-$700 and 10 weeks from crower.
Leitner is offline
Old 08-30-2005, 11:19 AM   #3 (permalink)
HondaVTEC93's Avatar
Car: 2006 Honda Civic Ex
HondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problem
gsr crank? woah...not working
2000 Elantra - demolished
1993 Civic Ex - built then sold
2006 Civic Ex - current
HondaVTEC93 is offline
Old 08-30-2005, 11:25 AM   #4 (permalink)
Car: 00 Civic Coupe & 96 Civic Hatch
Mods: Nothing in there but the hamsters.
-=Zeqs=- is a jewel in the rough-=Zeqs=- is a jewel in the rough-=Zeqs=- is a jewel in the rough-=Zeqs=- is a jewel in the rough
You would need custom rods and pistons. Peak Performance makes a "stroker" kit for the B16A. It's got a 89 mm stroke...hmm...LS...custom rods, and custom pistons (most likely with the connecting rod pin moved up). However, it's not recommend that you do this, or with the GSR crank, if you like to have your engine cable of high revs with durability. Turns the rod-stroke ratio into a shitty one.
Zero - 00 VSM EX Coupe
Password CF Intake
Carsound CAT
Function Form Coilovers
ST Sways front and rear
99-00 Si Rims
Epyon - 96 VSM DX Hatch
AEM Intake
BBR D16Y8 Head and tranny
DC Sports 4-1 Header
Rear disc conversion
D2 Coilovers
Hella 3rd Gear VTEC y0!
-=Zeqs=- is offline
Old 08-31-2005, 08:46 AM   #5 (permalink)
thanx for the replies
i ve thought about the rod stroke issue, and i was planning to add a block girdle and gsr oil pan main bolts and windage tray to install it..
also i was planning to top at 8400-8500 rpm
in conclusion to make this work i ll be also needing stroker pistons..
at least i ll be following the .. original stroker kit engine geometry that croer or toda etch sell..
the crank stroke is 89 right?
i d prefer a b18 ls or gsr block, but b18 never made it to greece, and blocks via usps ems is an expensive thing to order via usa.
10.7C.R
GROUNDING KIT
ADVAN A032R
STRUT BARS
HR SPORT SPRINGS
WWW.REDLINERS.GR
GREEKHONDACLUB
Old 08-31-2005, 11:53 AM   #6 (permalink)
They had 1.8 liter blocks in Europe though...B18C4...also...the Civic Type R which could be found in Europe, offered a 1.6 liter engine which was a DESTROKED B18C engine. Basically they took a Type R engine, used a crank that offered a 1.6 liter stroke, with longer rods.
Password CF Intake
Carsound CAT
99-00 Si Rims
AEM Intake
D2 Coilovers
-=Zeqs=- is offline
Old 09-06-2005, 08:49 PM   #7 (permalink)
WhiteHotEhHatch is on a distinguished road
Stick with the stock stroke, stick in the p30's, some lumpy cams, a good valvetrain, launch at 6k and dont look back. Just my .02
Aerodynamics are for people who cant build engines.
WhiteHotEhHatch is offline
