Old 06-01-2006, 08:20 PM   #1 (permalink)
Sirfallsalot243's Avatar
Car: 1998 Nissan 240sx SE
Cam Questions...
I scored a set of Crower 63403 Stage 3 cams for my B18C1 that im building, and am currently looking for springs and retainers. Damn, i had no idea they were so expensive. Almost $500 for Manley's and $600 for Crower. I found these springs and retainers by Supertech, and i was wondering if they would be OK to use with my cams?
http://cgi.ebay.com/ebaymotors/Super...QQcmdZViewItem
Seat Pressure: 70 lbs @ 33.5mm
Open Pressure: 190lbs @ 12.0mm
Max Lift: 12.5mm
Coil Bind: 19.5mm
Theyre only $330, which helps me out a LOT.
Also, this will be my setup hopefully:
Skunk2 intake manifold
JDM ITR 4-1 header w/ 2.5" collector
Comptech intake/icebox
Apexi N1 exhaust
B16 pistons w/ hastings rings
ACT stage 1 clutch
Exedy 9.5lb flywheel
Crower 63403 stage 3 cams
Supertech springs and retainers
VAFC2
Where should I be at as far as power?
Thanks for the help guys.
ALL Motor B18C1
Integra Arsenal:
1991 LS Special Ed- Sold.
1998 Nissan 240SX SE New!
And a 2000 Suzuki SV650
Sirfallsalot243 is offline
Old 06-02-2006, 01:36 AM   #2 (permalink)
Premium Member
·Àdministrator·
JDM_Honda's Avatar
Car: 2003 VW GTi
Mods: CDA intake. 20psi. 3" full exhaust. Bailey's dv.
JDM_Honda You need a lifeJDM_Honda You need a lifeJDM_Honda You need a lifeJDM_Honda You need a lifeJDM_Honda You need a lifeJDM_Honda You need a lifeJDM_Honda You need a lifeJDM_Honda You need a lifeJDM_Honda You need a lifeJDM_Honda You need a lifeJDM_Honda You need a life
Looks like you'll be starving those cams to death. you really need some P73 pistons or even P30, I think 11.5 is the least compression you should run with cams that big. As far as power, you can't really say much, i can tell you that with this set up crower stage 2 cams will deliver more power. At least 180whp should be expected though. You also need a better tuning source. Good luck with your set up.
'97 Prelude Type SH *Sold*
'98 B18C swapped EJ6 *Sold*
'03 GTI 1.8T
My myspace!
JDM_Honda is offline
Old 06-02-2006, 01:24 PM   #3 (permalink)
All the research ive done said that these cams recommend a compression increase, but dont require it. The cam profiles are less agressive than Skunk2's stage 2.
Im going with Manley retainers because they come with the keepers so that the valves dont drop. Most retainers use the OEM ones. I just need to find some springs.
ALL Motor B18C1
Integra Arsenal:
Old 06-02-2006, 01:41 PM   #4 (permalink)
Iron Monk
Mods: Go-fast stuff, Alpine 9855, Infinity Perfect 10.1 & 6.1 w/ a few hundred watts on each via Pioneer 5100T & 7100M.
Nathan123 Hello down there miniscule peonsNathan123 Hello down there miniscule peonsNathan123 Hello down there miniscule peonsNathan123 Hello down there miniscule peonsNathan123 Hello down there miniscule peonsNathan123 Hello down there miniscule peonsNathan123 Hello down there miniscule peonsNathan123 Hello down there miniscule peonsNathan123 Hello down there miniscule peonsNathan123 Hello down there miniscule peonsNathan123 Hello down there miniscule peons
Damn... the Honda aftermarket robs you guys blind.
That's REDICULOUS for the specs. A set with almost double the strength is cheaper for a Corvette.
'02 EB Z06
mods: Vararam intake, Breathless bridge, Dynatech Supermaxx SS headers & X-pipe, Breathless shifter, Dyno tuned (~400 RWHP).
1/4: ???
SOLD:
'01 Camaro SS M6 (Lid & Nitto 555Rs, best 12.6@110)
'95 Formula M6 (CAI, Mac hdrs/Y, cutout, SZ50EPs, best 13.6@103)
Nathan123 is offline
Old 06-03-2006, 05:31 PM   #5 (permalink)
Car: 95' GSR
Mods: one slow LS
Yambor is an unknown quantity at this point
lego build..
id recommend supertech valvetrain, but with some more compression, you'll be dissapointed IMHO.
VTEC®
"Respect is 1320 feet away..."
F/S: JDM ITR Pistons w/ rings OS .25mm
F/S: Cometic B-Series VTEC H/G 3 Layer
ASE Mait. And Work on Your car..WV/VA/MD PM ME
Yambor is offline
Old 06-04-2006, 09:45 AM   #6 (permalink)
I ended up going with Supertech springs and the Manley retainers. I think to bump the compression a bit more, ill use a thinner head gasket.
Is it ok to use 1 of the layers of the OEM head gasket? Ive heard of people doing this, but it seems ghetto. But on the other hand, whats the difference between 1 layer of OEM gasket, and a 1 layer Spoon or Mugen gasket? Are these OK to use? I dont want to pay $150+ for a fucking gasket.
ALL Motor B18C1
Integra Arsenal:
Old 06-04-2006, 11:22 AM   #7 (permalink)
Car: 95' GSR
Mods: one slow LS
you could buy an OEM gasket and use 2layers of it.. or just break down and buy a spoon one...haha
VTEC®
Yambor is offline
Old 06-04-2006, 02:22 PM   #8 (permalink)
Using one wont work?
ALL Motor B18C1
Integra Arsenal:
Old 06-04-2006, 08:08 PM   #9 (permalink)
Car: 95' GSR
Mods: one slow LS
thats the most ghetto ever..
just get a 2 layer, or use 3layer and just mill head more
VTEC®
Yambor is offline
Old 06-16-2006, 02:13 PM   #10 (permalink)
I just used a compression ratio calculator, and got the following results:
B18c with B16 pistons and OEM head gasket: 11.28:1
B18c w/ B16 pistons and 2 layer head gasket: 11.5:1
B18c with B16 pistons and 1 ply head gasket: 11.83:1
Stock B18c: 10:1
I may break down and get the 1 ply gasket. 11.83:1 is a pretty decent compression ratio for those cams. Are thinner head gaskets more prone to blowing?
ALL Motor B18C1
Integra Arsenal:
Old 06-17-2006, 07:52 PM   #11 (permalink)
shaolin_style is sad...just sadshaolin_style is sad...just sadshaolin_style is sad...just sadshaolin_style is sad...just sadshaolin_style is sad...just sadshaolin_style is sad...just sadshaolin_style is sad...just sadshaolin_style is sad...just sadshaolin_style is sad...just sadshaolin_style is sad...just sadshaolin_style is sad...just sad
I use supertech springs/retainers with skunk 2 stage 2's and rev em up to 10k no problem. Tom at Portflow recommended them for me and he knows this shit..its his life haha.
shaolin_style is offline
Old 06-19-2006, 08:31 AM   #12 (permalink)
9400rpms's Avatar
Car: 1997 Acura integra GS-R
Max Lift: 12.5mm
Coil Bind: 19.5mm
Apexi N1 exhaust
ACT stage 1 clutch
VAFC2
You'll be fine.. believe me, the CR you have now is more then fine for the stage 3 crowers, they aren't that big..Secondly, i wouldn't buy something as important as a valvetrain off ebay, but thats just me..
I've ran comp cams,crane cams, crower cams and i'm on skunk2 stage 2 now...the s2s2's have out proformed all of these cams by FAR..
The crane stage 2's = crower stage 3's basically..and to be honest..
I suggest either a toda or crower valvetrain..crower.com has some good info..about their springs.
Support ECTUNE - Ectune.com
I Follow No One.
9400rpms is offline
