That looks cool with the clear window in the valve cover. First time I saw a coil on plug setup was on the Ford OHC V8 a few years ago. Dude pulled the coil cover off when he was getting dyno'ed to connect the pickup. Becoming more and more common now.
Gives a nice clean look to an engine bay not having a coil packs or distributor and plug wires.
Better spark would be a given, no plug wire, no voltage drop.
2000 V6 5-speed Mustang not stock 14.8 @ 93 MPH
2004 V6 5-speed Auto Accord Coupe stock so far :evil
Mustang - K&N FIPK, 3.73 gears with Trac-loc, dual-exhaust, phonelic intake spacer, steeda tri-ax shifter, billet clutch quadrant, ASP underdrive pulley, X2C upper and lower rear control arms, KYB AGX front struts.
Member of PACT - People Against Clear Tail-lights
