08-26-2005, 12:28 PM
#1 (permalink)
Car: 2004 Volkswagen Golf R32
Dot it yourself ITB's
Cut some tubes.........
Buy some GSXR throttle bodies off Ebay for cheap........
Cut your factory intake......
Buy or assemble at MegaSquirt programmable fuel injection box
rodney at http://www.rs-autosport.com
Get an air filter, throttle cable, etc and bolt in on for a test fit
Wire it all up, use your laptop to program
For more info http://www.megasquirt.info/
Men with guts attack those corners!"  :
-Keiichi Tsuchiya
Originally Posted by katsi
danmakG60 is a god
THE TT IS DEAD
[img] [/img]
Standard Disclaimer - Don't believe everything on the internet. Including what i say.
My Myspace!
08-26-2005, 12:32 PM
#2 (permalink)
For less than a quarter of the price of buying Toda or similiar you can run ITB's. I have setup 3 cars so far and it works great.
-Keiichi Tsuchiya
danmakG60 is a god
THE TT IS DEAD
[img] [/img]
My Myspace!
08-26-2005, 03:46 PM
#3 (permalink)
Car: 95 civic
how is part throttle
gotta get that pump...
08-26-2005, 04:21 PM
#4 (permalink)
Car: 2006 Honda Civic Ex
cool
2000 Elantra - demolished
1993 Civic Ex - built then sold
2006 Civic Ex - current
08-26-2005, 07:45 PM
#5 (permalink)
Part throttle is alot more than you get with a single tb, but it's not too bad once you get used to it. If you use a long throw throttle cable it's not bad.
-Keiichi Tsuchiya
danmakG60 is a god
THE TT IS DEAD
[img] [/img]
My Myspace!
08-26-2005, 08:10 PM
#6 (permalink)
Car: 1995 Acura Integra LS
nice
09-01-2005, 02:37 AM
#7 (permalink)
Just finished these for my brothers 2.0l Rabbit. Idles awesome and revs fast as hell, so much fun to drive. N/A at it's best right here.
-Keiichi Tsuchiya
danmakG60 is a god
THE TT IS DEAD
[img] [/img]
My Myspace!
09-02-2005, 02:19 AM
#8 (permalink)
Car: 00 Civic Coupe & 96 Civic Hatch
Mods: Nothing in there but the hamsters.
You ever thought about building some and selling them?
Zero - 00 VSM EX Coupe
Password CF Intake
Carsound CAT
Function Form Coilovers
ST Sways front and rear
99-00 Si Rims
Epyon - 96 VSM DX Hatch
AEM Intake
BBR D16Y8 Head and tranny
DC Sports 4-1 Header
Rear disc conversion
D2 Coilovers
Hella 3rd Gear VTEC y0!
09-04-2005, 05:41 AM
#9 (permalink)
dont give him the idea cuz then we'll have to buy em from him
no honda.......yes nissan....
09-04-2005, 06:54 AM
#10 (permalink)
Lifeless Ninja
pretty good write up. wish it was more in detail..
"Your Mind is your first enemy."
09-04-2005, 08:21 PM
#11 (permalink)
What do you need to know? I can try my best to answer your questions.
-Keiichi Tsuchiya
danmakG60 is a god
THE TT IS DEAD
[img] [/img]
My Myspace!
09-04-2005, 08:50 PM
#12 (permalink)
are those tubes from home depot or something? what type of material is it?
09-05-2005, 12:48 AM
#13 (permalink)
Any metal supply shop will have aluminum tubes in various diameters, including sheets, and scrap pieces laying around already cut. Every car is going to be different as this is a do it yourself venture, so cutting/measuring, and fitting is a given.
-Keiichi Tsuchiya
danmakG60 is a god
THE TT IS DEAD
[img] [/img]
My Myspace!
09-05-2005, 07:10 AM
#14 (permalink)
Lifeless Ninja
im not too good with wirings and computer stuff. but how exactly do you install the fuel management system? if i buy one, is it just plug and play?
and my car has an air intake temp sensor (those pointy ones) how would i go and plug that in?... and what about the plug in hose for the pvc valve?
09-05-2005, 06:56 PM
#15 (permalink)
However, I would not reccomend Megasquirt for Hondas since there are so many other easier solutions out there for Honda fuel management. I would just run Uberdata since it doesn't require you to build an ECU and rewire your motor. As far as your air intake sensor, you can either install it in your air filter, or put it in close proximity to your filters. The PCV valve tube can be connected to a vacuum nipple off your primary vacuum source.
-Keiichi Tsuchiya
danmakG60 is a god
THE TT IS DEAD
[img] [/img]
My Myspace!
