Old 09-12-2005, 05:37 PM   #1 (permalink)
sibluelude is an unknown quantity at this point
How can i get my prelude into the low 14s??
I have a 2001 prelude base with an h22 in it. My current mods are AEM short Ram, DC sports header, Apexi N1 exhaust. My question is what can i do to get it to low 14s while staying N/A. What would be the best setup?
sibluelude is offline
Old 09-12-2005, 05:42 PM   #2 (permalink)
expierence97's Avatar
Car: 99 Prelude Type SH, 83 RX7 GSL
expierence97 What did you do to deserve all this rep?expierence97 What did you do to deserve all this rep?expierence97 What did you do to deserve all this rep?expierence97 What did you do to deserve all this rep?expierence97 What did you do to deserve all this rep?expierence97 What did you do to deserve all this rep?expierence97 What did you do to deserve all this rep?expierence97 What did you do to deserve all this rep?expierence97 What did you do to deserve all this rep?expierence97 What did you do to deserve all this rep?expierence97 What did you do to deserve all this rep?
It depends what you want to do, there are tons of options.
I'm sure if you got a better header, 15's, drag radials, some weight reduction, and of course good driving you could pull out low 14's. Maybe even get a jdm h22 and work on that.
Good luck.
PFC USAR - Light Weight Vehicle Mechanic
83 RX7 GSL: LS1 and other go fast goodies
99 CMB Prelude Type-SH:
Type-s swapped, type-s front lip, type-s front strut bar, progress adjustable rear sway bar, jdm fogs, mugen exhaust, SRI, mugen coilovers, mugen thermopak, competition clutch(stage 3)/flywheel, hawk HP+ brake pads, CF hood/trunk... and more to come.
Autocross is for drivers.
Drag racing is for cars.
Prelude FAQ
expierence97 is offline
Old 09-12-2005, 05:53 PM   #3 (permalink)
what kind of header would u recomend? I always thought a dc sport header was a good header.
Old 09-12-2005, 06:35 PM   #4 (permalink)
Car: 92 hatchy dx
Mods: LS swap
padnic has a little shameless behaviour in the past
i think ur gona need a lot more than just the basic i/h/e to get low 14's...cams, mild head work and tuning will prbly get u there...but what do i know..i love paintaball guns..
proud owner of a black 04 spec V
padnic is offline
Old 09-12-2005, 06:58 PM   #5 (permalink)
ksniperfox's Avatar
Car: 90 rex si
Mods: JR edition GT killer
megan racing is better, but there are still better ones than that. dc=cheapest brand name. 4-1=best for top end power. its hard to make a lot of NA engine power without spending an assload of money. dont forget that there are other areas you can imporove to lower ET. weight reductions/gutting the car, improve r/t, better tires, etc.
'90 crx Si
MY VIDEO(old setup)
Originally Posted by Snoopy
ksniperfox is offline
Old 09-12-2005, 07:08 PM   #6 (permalink)
No, DC sucks.
Here's a thread on SMSP, or you could always go for RMF, or Hytech, something along those lines.
SMSP header comparison with stock JDM header, +16whp untuned
(While i'm on the subject of NA ludes on the 1/4- 5th gen Built Head, quarter mile video Check out his work for his times.)
But I'm still thinking that with a custom header, I/E, carbon fiber hood and trunk, all the shit out of your trunk gone, light weight 15's, drag radials and good driving you could pull low 14's.
Didn't lookat me run a 14.6 with his base lude (I/H/E and 15's.)?
And nicolo... go paintball...
Prelude FAQ
Old 09-12-2005, 07:38 PM   #7 (permalink)
sleeper15's Avatar
Car: 92 Honda Civic SI
Mods: GSR motor, build to N/A glory
sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?
Well, gettin a FWD car into the 14's is hard. You need more then just power to get into the 14's. ANyways, takin weight off your car is always a good way to imporve trap times. I think it goes for ever 100 pounds removed = .1 sec of your ET.
ALso, removing the a/c, or just taking off the belt would ad in HP just a little, same with the power steering pump, even though the PS pump is kinda dangrous to do, but, since you plan on going just straight, it might be an idea.
Like others have mention, motor wise, you'll need a little head work. Nothing much, seeing that the H22 is quite a motor to begin with. Mild port and polish. Slightly larger throttle body, fuel injectors. Mild cam (nothing to agressive to bring drivablity down). LIghten pulleys (or underdrive pulleys).
Those are just some mild things you can do. Don't forgot suspinsion set up, and rim weight as well. Well, good luck on your quest for 14 secs.
'92 Honda Civic SI- GSR swap, full N/A build.
It's so badass, people stop looking at porn cause of it.
My EG6
'01 Subaru Impreza 2.5RS (SOLD)
'01 Dodge Dakota R/T, RIP. Wrecked
'00 Dodge Durango R/T - The new whip
Konnichiwa from japan bitches!
Myspace
sleeper15 is offline
Old 09-12-2005, 09:05 PM   #8 (permalink)
thanks for the help guys, im new to the honda world and considering i used to own a mustang gt and only ran a 14.5 with it and i just wanna be able to say my honda was faster then my v8 so i didnt know what to do after h/i/e
Old 09-14-2005, 06:58 PM   #9 (permalink)
lngbchkd83 is on a distinguished road
why'd you get rid of the stang?
lngbchkd83 is offline
Old 09-14-2005, 09:09 PM   #10 (permalink)
I blew up the engine, i was planning on fixing it but didnt feel like dealing with that car anymore with gas and insurance so i got a prelude. i havent decided what im gonna do with the stang yet. i might wait and save some money and drop a nasty engine in it or sell it. someone wants to buy it but i havent decided yet so right now i still own it. dunno what to do yet
Old 09-14-2005, 09:37 PM   #11 (permalink)
Clone's Avatar
Car: 2001 Honda S2000
Clone is sad...just sadClone is sad...just sadClone is sad...just sadClone is sad...just sadClone is sad...just sadClone is sad...just sadClone is sad...just sadClone is sad...just sadClone is sad...just sadClone is sad...just sadClone is sad...just sad
just sell it... ford builds crappy cars anyway.
2001 Honda S2000
201.63 whp : 135.74 ft/lbs
Myspace
Clone is offline
Old 09-14-2005, 09:48 PM   #12 (permalink)
Cypher Wave
Mods: h23vtec
98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy
get some nice tires and a good suspension. I ran 14.9 with i/h/e tuned vafc.
Lookatme in the prelude forum ran 14.6 on 15" lightweights with drag radials, i/test pipe/exhaust
98vtec is offline
Old 09-20-2005, 06:08 PM   #13 (permalink)
blacktraxgirl's Avatar
Car: lude
Mods: too many to list.
blacktraxgirl Rep God/Goddess with nothing better to doblacktraxgirl Rep God/Goddess with nothing better to doblacktraxgirl Rep God/Goddess with nothing better to doblacktraxgirl Rep God/Goddess with nothing better to doblacktraxgirl Rep God/Goddess with nothing better to doblacktraxgirl Rep God/Goddess with nothing better to doblacktraxgirl Rep God/Goddess with nothing better to doblacktraxgirl Rep God/Goddess with nothing better to doblacktraxgirl Rep God/Goddess with nothing better to doblacktraxgirl Rep God/Goddess with nothing better to doblacktraxgirl Rep God/Goddess with nothing better to do
honestly it all depends on how much time and money you want to put into the car. Intake wise you have a few options. AEM CAI is always okie.... ITBs or custom intake mani is an option too.
for a header youll want something like a jdm or mugen to start or SMSP or Hytech are the higher end headers.
bottom end work is a good idea depending on like i said the amount of time and money you plan to put into it.
head work is pretty essential to meet the low 14s. at least a gasket match p&p with a good valve train.
next step is great tuner and a good tuning device. Hondata is always safe bet but now that Neptune is coming thats also an option.
i have to say that hitting low 14s was a challenge and now that im in the high 13s on BFGs my next task is low 13s to high 12s ...but ive done extensive engine work and im still not done.
earlier in this thread someone posted a link to one of our cars. hes a great driver and honestly so am i... so that said getting your driving down will help a lot.
Team Trinity Lady Racers
"Ladies FIRST....that's how we finish"
http://www.driftbattle.org
http://www.blacktrax.net
Vouch List: 98vtec
blacktraxgirl is offline
