Yeah, we're all practically a bunch of ignorant kids.
Pretty sure you're going to get some CEL's running an MPFI ecu with no fuel injectors hooked up... The MAP is likely to always give you problems, any setup without a plenum will throw off the operating vacuum range. To even come close you will have to tap all the runners on the carb manifold into a vac manifold and run the MAP from that. I'm sure there are other issues.
Anyways d-i-y itbs have been done many times with bike throttle bodies for a fraction of the cost of prefab aftermarket setups using these same ideas.
Also, it's a great idea to make your first post on a forum one that insults other members and assumes they don't know anything.
