Old 02-23-2006, 12:01 PM   #1 (permalink)
ferrallas is an unknown quantity at this point
How to install a block guard
Hello!, Im thinking in install a block guard in my B16, but I dont have clear the procedure for do it, press the block guard in cylinders with a rubber mallet and leave the block 1.5mm down the gasket? Is needed hone & bone the block after installa the Blockguard?
If someone could illuminate me
THanks
ferrallas is offline
Old 07-10-2007, 10:09 PM   #2 (permalink)
fox hound What did you do to deserve all this rep?fox hound What did you do to deserve all this rep?fox hound What did you do to deserve all this rep?fox hound What did you do to deserve all this rep?fox hound What did you do to deserve all this rep?fox hound What did you do to deserve all this rep?fox hound What did you do to deserve all this rep?fox hound What did you do to deserve all this rep?fox hound What did you do to deserve all this rep?fox hound What did you do to deserve all this rep?fox hound What did you do to deserve all this rep?
Lightbulb
would like to know the answers for these questions 2
fox hound is offline
Old 07-11-2007, 01:37 AM   #3 (permalink)
BurntRubber87's Avatar
BurntRubber87 has a Rep problemBurntRubber87 has a Rep problemBurntRubber87 has a Rep problemBurntRubber87 has a Rep problemBurntRubber87 has a Rep problemBurntRubber87 has a Rep problemBurntRubber87 has a Rep problemBurntRubber87 has a Rep problemBurntRubber87 has a Rep problemBurntRubber87 has a Rep problemBurntRubber87 has a Rep problem
I'm pretty sure you should take it to a machine shop, have them press it in, then have them check the sleeves for straightness, and all that good stuff.
BurntRubber87 is offline
Old 07-13-2007, 01:53 PM   #4 (permalink)
ek9wannabe's Avatar
Car: 1993 civic dx
Mods: 93 hatch, 1.9 Ls/vtec
ek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sad
block guard huh.......i was never a fan of them, but i have installed them......the best way i found to install one is to put it in the freezer for about an hour or so, the install it in the block(its still gonna be a bear), then take the block to the machine sop for a final hone and or bore if needed
ALL MOTOR LS/VTEC
192 whp/128 tq
well 200 HP just wasnt cuttin it, goin turbo this time check out my build thread
http://www.superhonda.com/forum/showthread.php?t=330267
1990 crx SI zc swap
1993 civic dx NA ls/Vtec
2000 civic ex on boost: sold
ek9wannabe is offline
Old 07-18-2007, 07:26 AM   #5 (permalink)
noway is an unknown quantity at this point
Thumbs up
Easy to install. Wipe the outside cylinder surface and opposing block surface with acetone. If you do not intend to weld the fitted guard in place (KMS recommends welding the fitted guard in place) then apply a small amount of red loc-tite to 6-8 points along the guard side. Next, position the block guard with the arrow facing up and toward the front (timing belt side) and tap into place with a rubber mallet. Fit the block guard 1.5mm below the deck surface, MAKE SURE you align block guard loosly on top of deck to insur proper sizing and placement.
noway is offline
Old 07-18-2007, 03:40 PM   #6 (permalink)
9400rpms's Avatar
Car: 1997 Acura integra GS-R
good walkthrew, and quick and he is correct.. on the process
however. installing a block guard does knock your cyl's out of wack slightly, having them rehoned would be a good idea to be safe.. but if ur goin to do that, simplely let a machine shop do it for you, shouldn't be more then a 100 bucks for a hone/ install of a block guard.. its very simple to do but the slightless mistake can cost you big money.. block guards are worthless, because they only protect the top portion of the sleeve, being that most of the cracks do happen there, you fail to get the full effect if a rod or something is being slung, you do stand a chance of mininal damage, but anywho...their ok.. i guess..i wouldn't run one..
Support ECTUNE - Ectune.com
I Follow No One.
9400rpms is offline
