05-03-2007, 12:17 AM
#1 (permalink)
Car: GS-R
Individual Throttle bodies
i know the good but what's the down side of getting ITBs?
05-03-2007, 12:57 AM
#2 (permalink)
Car: 1998 Nissan 240sx SE
Its an INCREDIBLY huge bitch to tune.
So much so that it makes it not worthwhile on a street driven car.
ALL Motor B18C1
Integra Arsenal:
1991 LS Special Ed- Sold.
1998 Nissan 240SX SE New!
And a 2000 Suzuki SV650
05-03-2007, 04:16 AM
#3 (permalink)
Car: 1993 civic dx
Mods: 93 hatch, 1.9 Ls/vtec
bye bye low end power
ALL MOTOR LS/VTEC
192 whp/128 tq
well 200 HP just wasnt cuttin it, goin turbo this time check out my build thread
http://www.superhonda.com/forum/showthread.php?t=330267
1990 crx SI zc swap
1993 civic dx NA ls/Vtec
2000 civic ex on boost: sold
05-03-2007, 05:24 AM
#4 (permalink)
Car: 89 S13 Coupe, 95 S14
Mods: Over Drift gauge, Slide mode EFI, Smoke controller, Zip Tie meter, Cone G-force sensor
you'll be louder then the most V8's out there.
that's the down part.
and worrying about dirt/spics getting into your internals
05-03-2007, 07:56 AM
#5 (permalink)
Um... no.
Try the exact opposite.
ALL Motor B18C1
Integra Arsenal:
05-03-2007, 10:03 AM
#6 (permalink)
Car: 98 Civic Ex Coupe
Originally Posted by Sirfallsalot243
Um... no.
Depends on the size of the throttle bodies.
05-03-2007, 10:12 AM
#7 (permalink)
Generally speaking, ITB's will always make better low end than a manifold/TB setup, assuming theyre not rediculously huge on a rediculously small engine.
ALL Motor B18C1
Integra Arsenal:
05-03-2007, 11:45 AM
#8 (permalink)
Dark Wind
Car: something with wheels
Mods: whole lot of nothing
properly sized itb's to match the displacement of the engine and correct manifold design will make nice power throughout the powerband. it's not as simple as saying "goodbye low end" or "you'll pick up tons on the topend".
which is why i like jenvey itb's over the more common twm's. they have seperate manifold designs for pr3 and p72 heads. twm's were designed on p72 heads and use a one size fits all manifold runner design. also with the jenvey's you can mix and match different size tb's and stacks to achieve the powerband you want.
filters and airboxes are also available so filtration is not an issue. if peak power is what you're after, a manifold and single tb would do you better. if you're looking for a broader powerband, itb's may be for you, but know what you're getting yourself into first as they are far from drop in and go.
05-03-2007, 11:47 AM
#9 (permalink)
Car: 1997 Acura integra GS-R
How about someone who "has" the itbs on his R chime in..
I just got my set of 50mm twm's on, and running..to be honest..took an hour to overall tune them.. working on the nicknacks was the harder part..
Tps rewiring, and the spring setup on itbs in gerenal will be different and need to be adjusted..
Now i haven't "Fully" tuned the car out, just fuel wise so i can drive it and beat on it alittle..i'm still waiting for some other things to come in before i start goin to 10k.. but the whole power situation itbs are there for the high end and throttle response u get.. You dont really lose any low end, infact i accelerate a hell of alot faster then i ever did, from a low roll..its quite retarded too..
I fine these itbs idle fine.. i'll even do a video..my car idles at 800rpms..no problems..  yes i'm a pretty good tuner as well , fact remains u gotta know what your doing.. i feel a huge increase in power..even making runs w/o vtec the car pulled insane until 8 k, on low cam.. with vtec on it wanted to pull past 9500rpms..which was stupid fast..and it got there quick.. in a blink of an eye my rpms would gain 3500rpms in seconds...their worth it, IF you know what your doing..
Support ECTUNE - Ectune.com
I Follow No One.
05-03-2007, 11:49 AM
#10 (permalink)
thing called chicken wire, and i dont run that, or hav ea cover on mine, and their fine..their very close to the firewall which provides for some protection..and to be honest..hwy driving or just crusing they aren't loud..
Vtec however..is a different story..u will go deaf.
I Follow No One.
05-03-2007, 11:51 AM
#11 (permalink)
so true its unreal..to be honest itbs aren't something for a weak hearted person.. my car was down 2MONTHS getting all the correct hoses, everything properly matched and sealed everything double checking thing and seals getting the tuning supplies everything has to be perfect...but the car cranked up on the first try...but it is a very very hard project.
I Follow No One.
05-05-2007, 08:33 PM
#12 (permalink)
Personally the only time I'll ever install ITBs is when my car becomes track only. Not drag but road. If you have the time to get them dialed in and have properly sized ITBs you can make power across the board.
07-12-2007, 05:34 PM
#13 (permalink)
Car: 1997 GSR
Mods: 98 JDM ITR swap, Comtech 4-2-1, JR Cat, RS*R exhaust, K&N OE filter, OBX*R fuel filter, Comtech strutbar, premium oils plugs wires. premium stereo/speakers
I've got a 98 jdm itr (210 crankHP) swap in my teg with good aftermarket header, intake, cat, catback with no check engine light and still able to pass CO emissions (barely). If tuned right how much gain do u think i'd make with the right ITB?
07-13-2007, 09:35 AM
#14 (permalink)
you wont gain as much power as u could with big cams, ported head and etc etc.. but you will increase Throttle response by alot and yes power will go up..but dont expect it to make u shit your pants..raise the compression, bigger cams, biggerexhaust, good tuning and then ya, u might drop a load.. stock blocks wont cut it unless u raise the compression / raise cyl pressure.
I Follow No One.
