Old 09-10-2006, 02:53 AM   #1 (permalink)
Integralover is an unknown quantity at this point
Keep it stock Or go B20/vtec
hey guys.. i just need help with one thing...Well im going to Put a STOCK GSR in my car and i have a b20b block laying around..so all my friends tell me to put that block and make a b20/vtec...But im not sure..i wanted to see what feedback i get from here first...Which would be better, And faster...Thanks
Integralover is offline
Old 09-10-2006, 10:00 AM   #2 (permalink)
ek9wannabe's Avatar
Car: 1993 civic dx
Mods: 93 hatch, 1.9 Ls/vtec
ek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sad
id stick with the gsr............i think u have to get differnt pistons for the b20 if the cylinders are out of spec(i dont think honda made o.s. pistons)
ALL MOTOR LS/VTEC
192 whp/128 tq
well 200 HP just wasnt cuttin it, goin turbo this time check out my build thread
http://www.superhonda.com/forum/showthread.php?t=330267
1990 crx SI zc swap
1993 civic dx NA ls/Vtec
2000 civic ex on boost: sold
ek9wannabe is offline
Old 09-10-2006, 11:56 AM   #3 (permalink)
Car: 1988 civic (J)
Mods: B20b B16 head CTR cams type R intake ITR header MSD ignition password whale penis intake spoon PR3 and VTEC controller Gea
xxxdoc is infamous around these partsxxxdoc is infamous around these parts
If you do a b20 do it right it will cost but it will smoke almost anything on the streets I call mine the street killer!
xxxdoc is offline
Old 09-10-2006, 01:45 PM   #4 (permalink)
Dark Wind
Snoopy's Avatar
Car: something with wheels
Mods: whole lot of nothing
drop in the b18c1 and build up the b20 on the side if you want to do a b20vtec
Snoopy is offline
Old 09-10-2006, 10:59 PM   #5 (permalink)
9400rpms's Avatar
Car: 1997 Acura integra GS-R
if u have 1200 to spare, do it, if not the b20vtec will be poop
lemme explain why
pistons / rods and crank are poo poo
max rpms is 7000 grand u dont use all of the gsr's head power..
u need that black to get honed and sleeved, pistons / rods a good comp ratio combo like 11.1 or 11.8 somewhere around there and a good crank, slap the stock gsr head on there and make 190whp and run low 14's and high 13's all day if tuned correctly..the gsr head i wouldn't worry about, i'd worry about the b20vtec block going..some people slapping shit competely together running a gsr ecu
the motor doesn't last longer then a month like that..thats why so many ls/vtec's dont last...ls block with a gsr or b16a head using a gsr or b16a ecu reving the piss out of it to 8200rpms when the ls bottem end can only handle maybe 7500rpms max and the b20..sucks even more max revs should be around 6800.
Support ECTUNE - Ectune.com
I Follow No One.
9400rpms is offline
Old 09-11-2006, 03:51 AM   #6 (permalink)
So i should not use the Gsr Ecu?....And if i use the b20 what crank Should i use the Gsr or keep the b20?
Old 09-11-2006, 09:01 AM   #7 (permalink)
9400rpms's Avatar
No, use the gsr ecu, but build that bottem end before u go reving the piss out of it.
I Follow No One.
9400rpms is offline
Old 09-11-2006, 09:30 PM   #8 (permalink)
Arrow
so should i keep ther b20 crank??
Old 09-11-2006, 10:28 PM   #9 (permalink)
Car: 1988 civic (J)
good luck with your build all I can say is my b20vtec is the shit It revs to 8400 and I drive it daily ..
xxxdoc is offline
Old 09-13-2006, 02:52 PM   #10 (permalink)
Dark Wind
Snoopy's Avatar
if you want to keep it 2L, yes. have it balanced and lightened.
Snoopy is offline
Old 10-01-2006, 12:22 PM   #11 (permalink)
Car: 1994 Acura Integra LS
Put the GSR in the car. Build the B20 while you're enjoying the GSR. Then swap is and get it built. B20 vtecs are nasty! <- in a good way that is.
Originally Posted by 9400rpms
lugnutRS is offline
Old 10-01-2006, 07:06 PM   #12 (permalink)
spikehairboy is on a distinguished road
im in the same predicament sell me your b20 block if u decide not to use it. but anyway theres no neeed to sleve the block keep it simple. hone the bitch get ctr pistons,dowel pin it and balance it the rest is common sense.
spikehairboy is offline
Old 10-01-2006, 08:37 PM   #13 (permalink)
9400rpms's Avatar
drive your car off a cliff..your giving this dude the wrong info because you do it, doesn't mean its right..
the rod bolts let loose at around 7500rpms you haven't been reving it that high for that long..and if you have, your running on pure luck.
I Follow No One.
9400rpms is offline
Old 10-02-2006, 06:17 AM   #14 (permalink)
I love that. You've officially been quoted.
lugnutRS is offline
Old 10-02-2006, 07:30 AM   #15 (permalink)
9400rpms's Avatar
Enlighten me on why i've been quoted..
your do realize your just making yourself look like a complete idiot when the stock Rods / Rod bolts of any b20 are really only safely reved to oooo around 7200-7500 maybe?? that puts added stress on a rod/rod bolt thats not made for those high rpms..it also stresses a crank that isn't balanced or again made for those high rpms..
i love it when idiots such as yourself try to take quotes such as mine and make fun of me..
i've built engines, i've tuned engines have you built b20vtecs u dumb idiot?? have you? because i've built 4 so far, and 3 with a gsr head, 1 with a type-r head and i dont care where the power is, they were only revved out until 7200 until those guys paid to either get better rods and rod bolts or their bottem end was fully built..
Stock b20's have a rev limit of 7000 grand or somewhere around that for a reason..your a dumb little fuck if you think my quote is wrong.
I Follow No One.
9400rpms is offline
