Old 08-10-2005, 03:12 PM   #1 (permalink)
HBracer will become famous soon enough
ls rod rev limit?
What would be the highest any of you ls/vtec people would rev stock ls rods?
I'm planning on ctr pistons on a stock ls rod if i can just to save alittle money. Would I be better off just going aftermarket or what?
My desired setup is this;
ls rods
ctr pistons
supertech valvetrain
ctr or itr cams
and the other basic bolt ons with a tough clutch
what do you think this would make? i'm hoping 175-185hp and 130-140tq
no honda.......yes nissan....
HBracer is offline
Old 08-10-2005, 04:29 PM   #2 (permalink)
Car: 92 civic hatch
Mods: greddy kit intercooled
flameboy2 is an unknown quantity at this point
u wont save money
u wont save money that way , eagle rods are like only $380.00 or something , u will get some peace of mind reving eagle rods stock one's will do but the question is how long there's a reason why stock ls redline is 6800 rpm ...just a thought
how much u gonna pay for ctr pistons and rings anyway??
flameboy2 is offline
Old 08-10-2005, 04:37 PM   #3 (permalink)
I'm thinking they are 170 from hmotors
HBracer is offline
Old 08-10-2005, 09:11 PM   #4 (permalink)
kommon_sense's Avatar
Car: 98 Civic Ex Coupe
stock rev limit may be 6800 but it isn't due to weak rods. Only real reason to upgrade is if you can find significantly *LIGHTER* rods such as the crower n/a rods. However ARP rod bolts are always a plus.
kommon_sense is offline
Old 08-11-2005, 04:12 AM   #5 (permalink)
crower has the econo billet rods for right at $400 and they weigh 470g i think
HBracer is offline
Old 08-11-2005, 05:29 AM   #6 (permalink)
The crower n/a rods are even lighter
Old 08-11-2005, 05:46 PM   #7 (permalink)
yea but how much are they?
HBracer is offline
Old 08-11-2005, 07:12 PM   #8 (permalink)
About 600-700 a set... something like that... my point was that unless the eagles are *SIGNIFICANTLY* lighter, then they aren't worth the trouble unless they plan to push enough power to justify them.
Old 08-12-2005, 01:35 AM   #9 (permalink)
Car: 1993 Honda Civic EX Coupe
93civicdude is on a distinguished road
Now to mix it up... What about stock rods with a balanced rotating assembly and a block guard? (ignoring cooling issues)
If I'm not mistaken LS (or other "long stroking" honda) blocks have problems with side loading at high rpms.
93 EJ1-LS
- B18B1
- eBay CAI
- 96-spec JDM ITR header
- 2.25" custom exhaust with magnaflow muffler
- Omni-Power full coilovers, LCA's, and camber kit
- Powerslot drilled and slotted rotors in front
- Integra rear brakes
- Upgraded swaybars coming soon!
I <3 Torque!
Wrecked June 16th, 2005 and rebuilt! The official rebuild/buildup thread!
WTB: stock EM1 exhaust from cat back. PM me!
93civicdude is offline
Old 08-12-2005, 07:24 AM   #10 (permalink)
Why is the block guard needed? The author is shooting for less than 200whp...
Correct. However this is due to the r/s ratio. The only way to address this is with a different crank with a shorter stroke, or a longer rod.
Old 08-12-2005, 11:46 PM   #11 (permalink)
Thereby defeating the purpose of a LS/VTEC...
Ok, so what I was saying is if he wants to rev it, then he will have issues with side loading, which is why I suggested a block guard, to help reduce cylinder walk, in conjunction with a balanced rotating assembly... Am I wrong in suggesting this?
Also, how do you balance honda rods? Chevy V8 rods have balancing tabs on them that you can grind down to balance them, but I'm not sure what to do with a honda...
93 EJ1-LS
- B18B1
- eBay CAI
I <3 Torque!
Old 08-13-2005, 12:01 AM   #12 (permalink)
ls rods
ctr pistons
ctr or itr cams
I just noticed something... Do you realize how high your c/r will be with CTR pistons?
93 EJ1-LS
- B18B1
- eBay CAI
I <3 Torque!
Old 08-13-2005, 02:23 PM   #13 (permalink)
supposedly 12.4:1 but with a thicker head gasket it'll lower it and maybe a little grinding out of the combustion chamber
HBracer is offline
Old 08-13-2005, 06:59 PM   #14 (permalink)
It couldn't hurt, but I don't know that I've ever heard of anyone having these type of issues in a streetable n/a setup. If he was going turbo, then that would be a different story. Also depends on how high he is trying to rev it.
Old 08-13-2005, 09:42 PM   #15 (permalink)
revving to 9500-10k max
HBracer is offline
