Hey guys, i have a 97 integra gsr with 103000 miles on it. I briefly thought about adding a turbo, but i decided it wasn't the best option. So far i've added a dc sport cold intake and msd wires. I just had new belts, water pump, and distributor put in. I wanted to do some more mods and needed some advice. What would be the best mods to get more juice out of my engine. I was thinking about doing a cam swap and also adding a chip. Does anyone have any recomendations on which brands would work the best. thanks.
im seriously not hating on you, but how many more ways are people going to ask bang for the buck, or what will give *X* engine the most hp gains.
Off hand for you next if your staying all motor would be head work but to get the most out of headwork you need a good flowing exhaust setup, than to tune it all right you need a programed ecu.... see how there is a logical progression of sorts here.
And the man said: Live fast Die young And Leave a Good looking corpse
I've heard from countless people that running ITR cams, both intake and exhaust, will add some top-end power, which is all your gonna get with N/A bolt ons... I've heard the aftermarket cams aren't very good, no matter the manufacturer...
But, u need ITR dual-spring exhaust valve-springs so that u won't have valve float at high rpms, plus titanium valve-spring retainers are a must...
If u don't have a header, get a DC-sports 4-1 NOT 4-2-1. The 4-1 is optimized for high-rpms...
hmmm, what else...
Oh yeah, get ur ECU re-chipped...
Keep in mind, this will not really add much power or torque, in other words u will feel hardly any difference from the seat, but if ur torque curve is longer, cause of the cams and valve-springs being able to breathe better at extremely high-rpms (plus ECU ETC), u will gain top-end HP...
BTW, why not a turbo?? 103,000 mi is not bad, given regular maintenance...
U will notice far more power gained from a turbo...
Later
Hi all, I think I'm a know it all but in actuality I just making up for the fact that I have a small winky.
Later
exactly... took the words right outta my mouth.
if you want to achieve the same level of power by going with an NA setup opposed to going with a turbo route. i can assure you that you will be spending A LOT more money.
__________________ FOR SALE
104whp per wheel
bone stock 06 Audi A4 2.0t
$25,000
Thanks for the advice guys. The car's been pretty well maintained(wix filter with mobil 1 every 3000). The only thing i'd be concerned about with a turbo is the longevity of the engine. This car is my daily driver and the only car i have. Also, i've read the turbo and supercharger stickys and i can't decide which would be more suited for me. I don't really drag race much and i'm looking for something that would maintain the driveability. Thanks.
