N/A GSR Build...
Well i figured id sign up on SHO of all the years being on TI (AcuraRider14) and HT (yambor) and WVStreets, and other misc forums..
Its been a rough and long road with this engine.. going through lay offs, maitenance, and just plain not getting around to doing anything..
I started out with a purchase of a gsr engine, and gsr complete interior for 2800 back in 05'..
sat in the basement for a few months, got tired of looking at it so i put the gsr tranny on the ls.
then the engine has been sitting in my room until today, took the head and block down to Jim @ Justice Race Engines.Great Guy..
but enough with the talk, ill update accordingly.
Figured Id Post my build thread over here..
-Endyn Rollerwave 7.45cc Pistons
-12.2:1 Static CR
-Skunk2 Stage 2 Cams
-Skunk2 Cam Gears
-Supertech High Compression Race Valves Nitride Coated
-Supertech Magnease Bronze Valve Guides
-Supertech Ti Retainers
-Supertech Dual Valve Springs
-Blox Intake Manifold
-R/C Eng. 310cc Saturated Injectors
-Hondata Intake Manifold Gasket
-AEBS Head Studs
-ARP Rod Bolts & Resized Rods
-3 Angle Valve Job
-Spoon HG .45mm
-Milled .005"
-OEM Main & Rod Bearings & Thrust Washers
-OEM Bottom End Gasket Kit, all new seals...
-Skunk2 TB
-Toda Timing Belt
-OEM Honda Water Pump
-Hondata s300
-Walbro 190lph Fuel Pump
VTEC®
"Respect is 1320 feet away..."
F/S: JDM ITR Pistons w/ rings OS .25mm
F/S: Cometic B-Series VTEC H/G 3 Layer
ASE Mait. And Work on Your car..WV/VA/MD PM ME
