Originally Posted by gurusan
the OEM ignition setup is just fine unless you plan on making huge power (if I were planning on making over 350+whp I'd look into an upgrade)
However, since you already purchased it...it certainly won't hurt (except maybe your wallet  )
It has been used stock ignition on 700whp before, it works, and it works great.
If you gap the sparkplugs correctly and make shure your ignition system is in good shape you dont need other manufactures than OEM honda.
