Opinions on my setup to be B18
Okay- Right now I have a GSR Motor in my hatch it has a ported head with CTR Pistons and USDM ITR Pistons and Rods- The block was honed and head has 6 angle valve job- The head is milled. I have an AEM FPR and Fuel Rail. Custom header, Skunk2 Cam Gears, skunk2 intake manifold, Skunk2 chipped P28- I rev the car out to 9k but have hit 10k a few times- Now car smokes when in Vtec- So I'm going to build the bottom end- With Integra LS Crank Eagle Rods, CP 85mm 12.5 compression pistons. (I will actually be getting some 10.5:1 or so pistons putting the compression at about 12.5) Since I'm getting an LS Crank will I need new bearings or will the GSR's work??? A shop told me $300 for bearings??? Horsepowerfreaks told me to use the stock ones??? I will also be getting 310cc injectors and a VAFC2- Damn I post some stupid stuff- Someone here can help tho.
