Old 10-09-2007, 06:08 PM   #1 (permalink)
Dark Wind
tienlude's Avatar
Car: 92 prelude
Mods: jdm h22
tienlude you're still here?tienlude you're still here?tienlude you're still here?tienlude you're still here?tienlude you're still here?tienlude you're still here?tienlude you're still here?tienlude you're still here?tienlude you're still here?tienlude you're still here?tienlude you're still here?
orite SHO allmotor fehgs....and prelude genuises...
k, i came across a 92 prelude SINGLE cam NO vtec five speed....
bought a JSPEC
swapped it over...
i still got the no vtec ecu single cam
car wont even start...
when i put carb fluid in the throttle body it will turn but wont stay on..
ive checked my efi, got new dizzy, swapped injectors from low to high impedence and now are back on low, dumped out old fuel from when it sat now got fresh 93, its been jumped while kickin the efi...still nothing...
motor turns, but wont start...the fuel IS makin it past the filter...
..suggestions?
'92 with an H22J.
tienlude is offline
Old 10-09-2007, 06:16 PM   #2 (permalink)
Sirfallsalot243's Avatar
Car: 1998 Nissan 240sx SE
Getting spark?
Firing order correct?
ALL Motor B18C1
Integra Arsenal:
1991 LS Special Ed- Sold.
1998 Nissan 240SX SE New!
And a 2000 Suzuki SV650
Sirfallsalot243 is offline
Old 10-10-2007, 07:09 AM   #3 (permalink)
Dark Wind
tienlude's Avatar
Car: 92 prelude
Mods: jdm h22
got spark, order is correct.u can only get the wires soo mixed up, u know.
'92 with an H22J.
tienlude is offline
Old 10-10-2007, 08:52 AM   #4 (permalink)
GunMetal Member
H23lude92's Avatar
Car: 92 si
Mods: F22B-minor mods. intake, tanabe hyper medalion, neuspeed race springs, KYB shocks n struts
H23lude92 has a Rep problemH23lude92 has a Rep problemH23lude92 has a Rep problemH23lude92 has a Rep problemH23lude92 has a Rep problemH23lude92 has a Rep problemH23lude92 has a Rep problemH23lude92 has a Rep problemH23lude92 has a Rep problemH23lude92 has a Rep problemH23lude92 has a Rep problem
are you still running the ecu from the "s" engine? that could be your whole problem right there!
H23lude92 is offline
Old 10-10-2007, 10:37 AM   #5 (permalink)
It should still start. I dont claim to be an H-series know it all, but i do know that a B18C will start when using a P75 LS ecu, it just wont have vtec.
Are you sure your ignition timing is correct?
ALL Motor B18C1
Integra Arsenal:
Old 10-10-2007, 11:38 AM   #6 (permalink)
GunMetal Member
H23lude92's Avatar
Car: 92 si
same here, i know the F22 sohc came in the "s" ludes, while both h-series are dohc. so i could understand H23 / H22 ecu's working for eachother. im just not real sure about the F sohc ecu workin for the H series!
Old 10-10-2007, 12:31 PM   #7 (permalink)
Dark Wind
tienlude's Avatar
Car: 92 prelude
Mods: jdm h22
i swapped ecus for bit...sitll nada...today we figure it might be teh little silver box that works teh injectors(i forget the name)...we goin to replce it and see where it goes....timin is good....everything has been rechecked quite a few times for a week now...swap only took three hours, its been two weeks tryin to start it.
'92 with an H22J.
tienlude is offline
Old 10-10-2007, 12:33 PM   #8 (permalink)
The name of that part is the resistor box. Thats not where id be looking to find a problem. Pull the plugs- see if they smell like gas.
ALL Motor B18C1
Integra Arsenal:
Old 10-10-2007, 02:23 PM   #9 (permalink)
Dark Wind
tienlude's Avatar
Car: 92 prelude
Mods: jdm h22
and if the plugs smell like gas...then wat?
the resister box is for the injectors rite?
'92 with an H22J.
tienlude is offline
Old 10-10-2007, 03:23 PM   #10 (permalink)
The resistor box is to control peak and hold injectors on OBD0 cars. If your car is a 92, its obd1, and shouldnt even have a resistor box, unless you swapped out your injectors for peak and hold injectors.
If the plugs smell like gas, then you are getting gas into your cylinders, and fuel isnt the problem. They'd probably be wet after turning the motor over a few times.
ALL Motor B18C1
Integra Arsenal:
Old 10-10-2007, 11:18 PM   #11 (permalink)
Dark Wind
tienlude's Avatar
Car: 92 prelude
Mods: jdm h22
92-95 has them...dont know if 96 too.
no gas leak.
my harness is bad...only one plug works...i need a different harness...i cant use my obii harness...i got to find someone to trade my obd2 harness for an h23 harness...help me find one.
'92 with an H22J.
tienlude is offline
