Old 06-19-2006, 06:25 PM   #1 (permalink)
GS-X/RHatch is an unknown quantity at this point
AN-R Header Question
Is the AN-R header comparable to an SMSP or HyTech header? I have been looking around for which header I should buy for my car and it is a hard decision-
My setup will be-
GSR Block
GSR Head
82mm B16 Pistons
Skunk2 Pro2 Cams
Skunk2 Springs & Retainers
High Compression Valves
Buddy Club.5mm Head Gasket
Skunk2 Intake Manifold
Skunk 2 Cam Gears
AEM FPR/Fuel Rail
DSM 450cc Injectors
The head is already milled (not sure exact amount)
It will be tuned with Neptune and I would like at least 185whp
95 GSR Hatch - Type R Internals, CTR Cams, Ported head, 6 angle valve job, Skunk2 Intake Manifold/Cam Gears/Chipped ECU, AEM FPR, Fuel Rail, Intake, Phantom LSD, 4-1 - 2.5" exhaust,
99 Eclipse GSX - FP Red, AEM EMS, HKS 272's, Fidanza Cam Gears, DNP Tubular Manifold, Apexi GT Downpipe, HKS Carbon Fiber Ti Exhaust, Custom FP 02 Housing, Tial 46mm Wastegate, Blitz BOV, Greddy FMIC, 4 Gear Center Diff, Halman Pro Boost Controller, 400 awhp - Stock Internals!!! Running Strong
GS-X/RHatch is offline
Old 06-19-2006, 06:56 PM   #2 (permalink)
Sirfallsalot243's Avatar
Car: 1998 Nissan 240sx SE
Youll make 185 with that setup, if not 200.
ALL Motor B18C1
Integra Arsenal:
1991 LS Special Ed- Sold.
1998 Nissan 240SX SE New!
And a 2000 Suzuki SV650
Sirfallsalot243 is offline
Old 06-19-2006, 07:03 PM   #3 (permalink)
I hope so! You are running the JDM CTR Pistons? How do your cams compare to the SKunk 2 pro2?
Old 06-20-2006, 07:05 PM   #4 (permalink)
kommon_sense's Avatar
Car: 98 Civic Ex Coupe
I'd go smsp or hytech before an-r. I was very happy with the quality of my smsp header.
kommon_sense is offline
Old 06-20-2006, 08:23 PM   #5 (permalink)
Has anyone on here used the AN-R header??? If so what are your opinions?
Old 06-22-2006, 11:32 AM   #6 (permalink)
Car: 95 GSR
My brother just put and AN-R header on his engine. It sounds 10x better than a JDM ITR 4-1. As far as power gain he says its really sweet. I know a guy with a AN-R header on his built/overbored H22 putting down 243whp... He likes it, but claims theirs a dead spot in his power band.
Personally, if you're taxed for cash then get an AN-R, but if you want power and can shell out the bucks... SMSP! Its so worth it. Just look at the dyno charts.
Check out my old Si-T
uoboarder is offline
Old 06-22-2006, 12:44 PM   #7 (permalink)
Addictive will become famous soon enough
Six Sigma Racing aka DTR. Been very pleased with mine!!!!
Just something to think about.
--Mike--
Addictive is offline
Old 06-22-2006, 12:48 PM   #8 (permalink)
I have been looking all around and see there have been very good results from the Rage header. It helps a lot that the price is only $649 normal size and $699 for the bigger piping. I will most likely try this header out!
Old 06-22-2006, 03:07 PM   #9 (permalink)
road.head's Avatar
road.head Hello down there miniscule peonsroad.head Hello down there miniscule peonsroad.head Hello down there miniscule peonsroad.head Hello down there miniscule peonsroad.head Hello down there miniscule peonsroad.head Hello down there miniscule peonsroad.head Hello down there miniscule peonsroad.head Hello down there miniscule peonsroad.head Hello down there miniscule peonsroad.head Hello down there miniscule peonsroad.head Hello down there miniscule peons
wouldnt get an ANR solely because they are known to crack.
Wear Condoms. Ugly - Unintelligent babies are taking over the world and you are not helping
JDM H22a / Crower2 / RMF / NepTune RTP
Function > Form
Florida Prelude Forum
road.head is offline
Old 06-23-2006, 09:12 PM   #10 (permalink)
Im running USDM B16 pistons with a 1 ply head gasket. My CR is approx 11.8:1.
As for my cams, the Crower Stage 3's are actually smaller than the Sk2Stg2's.
ALL Motor B18C1
Integra Arsenal:
Old 06-24-2006, 09:29 PM   #11 (permalink)
Syn Inside03 is on a distinguished road
any updates?
Slammin 4 dr
Syn Inside03 is offline
Old 06-25-2006, 08:31 PM   #12 (permalink)
No one has answered about the Rage header!!!! I will be taking the car apart soon and hopefully get on the dyno before my date of sep 13 lol- Evans is really backed up-
Sirfalls- Let me know when you dyno your car and if you hit 200whp also if I hit 200 what do you think I would run with a 2250lbs car? With drag radials.
Old 06-25-2006, 09:10 PM   #13 (permalink)
No way to know really. If i had to guess... low 13s.
ALL Motor B18C1
Integra Arsenal:
Old 06-26-2006, 06:05 PM   #14 (permalink)
SH Virus
jeffry6996's Avatar
Car: 95 acura integra
Mods: TeH first and only Triple overhead Vtack m0tor!!
jeffry6996 Why haven't you checked into rep rehab yet?jeffry6996 Why haven't you checked into rep rehab yet?jeffry6996 Why haven't you checked into rep rehab yet?jeffry6996 Why haven't you checked into rep rehab yet?jeffry6996 Why haven't you checked into rep rehab yet?jeffry6996 Why haven't you checked into rep rehab yet?jeffry6996 Why haven't you checked into rep rehab yet?jeffry6996 Why haven't you checked into rep rehab yet?jeffry6996 Why haven't you checked into rep rehab yet?jeffry6996 Why haven't you checked into rep rehab yet?jeffry6996 Why haven't you checked into rep rehab yet?
what about the RMF headers?? does anyone know about these??
Commander and Cheif of the Get FRESH Crew 82nd Regiment
*****UNDER CONSTRUCTION****** (Again)
www.hondasofnewengland.comhttp://www.myspace.com/jeffry6996
Welcome back Teg or Non Teg related Bull Sh*t thread
jeffry6996 is offline
Old 06-26-2006, 08:39 PM   #15 (permalink)
road.head's Avatar
RMF is good for the soul
Function > Form
