Old 08-14-2005, 10:46 PM   #1 (permalink)
HondaVTEC93's Avatar
Car: 2006 Honda Civic Ex
HondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problem
Raise Compression
What's the best route to go to raise compression?
No poop stuff....just spill the facts and shoot out ideas.
Thanks ppl.
2000 Elantra - demolished
1993 Civic Ex - built then sold
2006 Civic Ex - current
HondaVTEC93 is offline
Old 08-15-2005, 03:59 AM   #2 (permalink)
Leitner is an unknown quantity at this point
pistons are where you should start. but many people will say cut the head and yes that is the easiest way. to me pistons are the starting point but hat requires a rebuild.
Leitner is offline
Old 08-15-2005, 06:05 AM   #3 (permalink)
Mr.60trim's Avatar
Car: Honda...Duh!
Mods: Classified Info
Mr.60trim In the rep troposphereMr.60trim In the rep troposphereMr.60trim In the rep troposphereMr.60trim In the rep troposphereMr.60trim In the rep troposphereMr.60trim In the rep troposphereMr.60trim In the rep troposphereMr.60trim In the rep troposphereMr.60trim In the rep troposphereMr.60trim In the rep troposphereMr.60trim In the rep troposphere
"Cut the head" Explain?
My NEW Motivation...
I My Honda
Project Boost Currently Aborted...New Project coming soon
Sale/Trade:
***Currently Parting Out My Car***
http://www.superhonda.com/forum/f47/...g-more-334934/
WTB:
Nada...
Mr.60trim is offline
Old 08-15-2005, 07:20 AM   #4 (permalink)
kommon_sense's Avatar
Car: 98 Civic Ex Coupe
Milling the head. This makes for a smaller combustion chamber which in turn raises compression. I'm not really a fan of this method.
If you really want to raise compression, then pistons are the way to go.
kommon_sense is offline
Old 08-15-2005, 08:30 AM   #5 (permalink)
Mr.60trim's Avatar
Car: Honda...Duh!
Ahhh...I C. Very interesting. Why are you not a fan? Possible damage could happen or something of that nature?
I My Honda
Sale/Trade:
WTB:
Nada...
Old 08-15-2005, 08:52 AM   #6 (permalink)
Cypher Wave
Mods: h23vtec
98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy
you have to worry more about piston to valve clearance when you mill the head.
You can only mill it so far before the valves hit the piston. Thats why if you mill the head then eventually throw high compression pistons in there, it "limits" you to what compression you can run.
98vtec is offline
Old 08-15-2005, 09:41 AM   #7 (permalink)
Mr.60trim's Avatar
Car: Honda...Duh!
That makes sense
I My Honda
Sale/Trade:
WTB:
Nada...
Old 08-15-2005, 09:46 AM   #8 (permalink)
Also, once you mill the head, that is material that you can *NEVER* add back and it does have a small impact on your cam timing.
It also limits how big of a cam you can run and you are also reducing your piston to valve clearance.
Don't get me wrong, milling works. I'd just rather pick my compression by using the right piston.
Old 08-15-2005, 06:43 PM   #9 (permalink)
yeah exactly...i would never mill it. maybe some ctr pistons and a gsr crank. some buddyclub spec III's was more what i was thinking...that would put me in the 12's
Old 08-15-2005, 07:48 PM   #10 (permalink)
sleeper15's Avatar
Car: 92 Honda Civic SI
Mods: GSR motor, build to N/A glory
sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?sleeper15 Why haven't you checked into rep rehab yet?
I did both. I milled my head, and added some High comp slugs. Unfourtnitly, i can't run any bigger cams then what i'm running now (Crower 402). Like kommen_sense says, once you mill the head, you can't changed what you did. It's a step you really have to be sure of.
'92 Honda Civic SI- GSR swap, full N/A build.
It's so badass, people stop looking at porn cause of it.
My EG6
'01 Subaru Impreza 2.5RS (SOLD)
'01 Dodge Dakota R/T, RIP. Wrecked
'00 Dodge Durango R/T - The new whip
Konnichiwa from japan bitches!
Myspace
sleeper15 is offline
Old 08-25-2005, 02:49 PM   #11 (permalink)
Car: 92-95 JDM civic Sir HB.
Blood is an unknown quantity at this point
How much would you gain by just going with a thinner head gasket
Blood is offline
Old 08-25-2005, 08:14 PM   #12 (permalink)
Cypher Wave
Mods: h23vtec
i havent read up too much on shaving the head but i would say if you shaved it 30 thousandths, that would prolly up the CR another half a point or so....so like 5 whp?
98vtec is offline
Old 08-25-2005, 08:49 PM   #13 (permalink)
Car: 2004 Volkswagen Golf R32
danmakG60 Um, 1 million? Damn!danmakG60 Um, 1 million? Damn!danmakG60 Um, 1 million? Damn!danmakG60 Um, 1 million? Damn!danmakG60 Um, 1 million? Damn!danmakG60 Um, 1 million? Damn!danmakG60 Um, 1 million? Damn!danmakG60 Um, 1 million? Damn!danmakG60 Um, 1 million? Damn!danmakG60 Um, 1 million? Damn!danmakG60 Um, 1 million? Damn!
1)mill head : requires adj. cam sprockets
2)pistons
3)thinner head gasket
Men with guts attack those corners!" :
-Keiichi Tsuchiya
Originally Posted by katsi
danmakG60 is a god
THE TT IS DEAD
[img] [/img]
Standard Disclaimer - Don't believe everything on the internet. Including what i say.
My Myspace!
danmakG60 is offline
Old 08-25-2005, 08:51 PM   #14 (permalink)
Cypher Wave
Mods: h23vtec
why is that?
Milling the head has nothing to do with timing.
98vtec is offline
Old 08-25-2005, 08:55 PM   #15 (permalink)
why is that?
Yes it does, you are making the head shorter thus putting the timing belt in another position. With a sprocket you can return your cam timing to exactly how it was before.
-Keiichi Tsuchiya
danmakG60 is a god
THE TT IS DEAD
[img] [/img]
My Myspace!
Digg this Post!
