Old 07-21-2006, 08:44 AM   #1 (permalink)
Car: 99 EM1
Mods: Bone Stocker
J_fukin_t is a splendid one to beholdJ_fukin_t is a splendid one to beholdJ_fukin_t is a splendid one to beholdJ_fukin_t is a splendid one to beholdJ_fukin_t is a splendid one to beholdJ_fukin_t is a splendid one to beholdJ_fukin_t is a splendid one to behold
skunk2 stg 1 cams & hondata
like title says i'm looking at possibly doing this, but a few questions?? how much h/p should i expect w/ those two and an intake mani & possible t/b, all of course w/ a good tune. thanks in advance
J_fukin_t is offline
Old 07-21-2006, 08:14 PM   #2 (permalink)
Dark Wind
Snoopy's Avatar
Car: something with wheels
Mods: whole lot of nothing
without knowing which engine it'll be going in i'll wager a guess of 1 bajillion hp
Snoopy is offline
Old 07-22-2006, 12:25 AM   #3 (permalink)
Car: 92 prelude
Mods: h22 with skunk2 top end, 12:1 cr, eagle rods, NA IS BEST!
blueh22 is an unknown quantity at this point
i'm gonna have to disagree and say 20 kazillion hp, more logical since there will be a good tune.
blueh22 is offline
Old 07-22-2006, 02:44 PM   #4 (permalink)
ek9wannabe's Avatar
Car: 1993 civic dx
Mods: 93 hatch, 1.9 Ls/vtec
ek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sadek9wannabe is sad...just sad
depends on your settings, cam timing, and the ability of your tuner
ALL MOTOR LS/VTEC
192 whp/128 tq
well 200 HP just wasnt cuttin it, goin turbo this time check out my build thread
http://www.superhonda.com/forum/showthread.php?t=330267
1990 crx SI zc swap
1993 civic dx NA ls/Vtec
2000 civic ex on boost: sold
ek9wannabe is offline
Old 07-24-2006, 12:46 AM   #5 (permalink)
Car: 99 EM1
Mods: Bone Stocker
my bad ppl its on a b16, but i found the #'s and i'm NOT gonna be wasting my money for maybe 20 whp
Old 07-31-2006, 05:39 AM   #6 (permalink)
Car: 98 integra gsr
Mods: 98 integra gsr - dc sports 4-1 polished,rs-r cat back,hight flow cat,msd wires,iridum plugs,pasword jdm intake,skunk2 pro intake manifold,skunk2 pro 68mm throtle body,skunk2 pro stage 2 cams,ctr pistons,N1 crank pullie,zex nitrous,itr suspention with coilover,energy suspention everything,dc sports short throw shifter and alot more
RoadRageMotors What did you do to deserve all this rep?RoadRageMotors What did you do to deserve all this rep?RoadRageMotors What did you do to deserve all this rep?RoadRageMotors What did you do to deserve all this rep?RoadRageMotors What did you do to deserve all this rep?RoadRageMotors What did you do to deserve all this rep?RoadRageMotors What did you do to deserve all this rep?RoadRageMotors What did you do to deserve all this rep?RoadRageMotors What did you do to deserve all this rep?RoadRageMotors What did you do to deserve all this rep?RoadRageMotors What did you do to deserve all this rep?
no you will not see a 20hp gain with just those 2 mods unless you are running very bad before your tune
correct me if i am wrong but skunk stage 1 cams a the sam lift and duration as stock just a harder grind os you will not gain from the cams at all and the hondata will only help if you have afew mods other than the basic bolt ons
it will take alot more to see a 20hp gain at the wheels
98 Integra GSR ssbp (current project/toy car)
91 Eclipse GSX (track car)
96 Dodge Stealth TT (garage Queen)
04 Miata Hardtop (daily driver)sold
06 Mazdaspeed 6 (new daily driver)
RoadRageMotors is offline
Old 09-13-2006, 08:10 PM   #7 (permalink)
xxsteve803xx is an unknown quantity at this point
20 wheel horse power is a sh!tload for an all motor car.
xxsteve803xx is offline
Old 09-14-2006, 12:51 PM   #8 (permalink)
Cypher Wave
Mods: h23vtec
98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy
im doubting its the same profile as stock. It would then be a stock cam....not a stage I
98vtec is offline
Old 09-14-2006, 01:13 PM   #9 (permalink)
9400rpms's Avatar
Car: 1997 Acura integra GS-R
Correct..
The s2s1's are basically a very..very mild cam
Their primaries are a little bit bigger then the CTR's / ITRS and the vtec lobes are pretty nicely sized for a stock block motor with out really any head work
max power range is around 8300ish's or so
here's the run down
Good health b16a's make around 140ish whp
if your running a mild bolt on system
thats a good intake, Header's 4-1 and a decent exhaust 2.5'' then you should see possible a 10-12 whp gain from those mods..maybe..
with hondata tuning and a skunk2 intake manifold with s2s1 cams i can definitly see 160whp range which depending on which car this motor is in, puts u in the mid - low 14's which is a pretty quick car..
if your goin to spend the money on stage 1's thats a good setup for say a nitrous or going with a supercharger
believe it or not..some cam tuning can unlock some hidden power..
your not goin to gain 20whp just by a set of cams..not without cam tuning, and ecu tuning..its very possible to see less or more, it depends on what your tuning and you can come up with.
and with cam timing a good rule of thumb is never seperate the cams more then 3 degress away from each other.. this insurese that you dont have valve to valve contact and/or piston to valve contact.
Support ECTUNE - Ectune.com
I Follow No One.
9400rpms is offline
Old 09-14-2006, 01:30 PM   #10 (permalink)
Car: N/A
RZFD is an unknown quantity at this point
Click the link in my sig, I have a cam guide posted in my blog. But yeah with all of that you may see a 15-20WHP gain, I'd at least go with some stage 2's and a slight bump in compression.
'99 EBP Si
Honda Resource: 3 hondas 2100+ WHP!
RZFD is offline
Old 09-14-2006, 03:05 PM   #11 (permalink)
9400rpms's Avatar
slight bump wont give him the go ahead to stage 2 cam a b16..sorry..
ctr pistons and a 2layer or 1 layer hg might give u a good compression to maximize those cams but i dunno..
stage 1 cams are idle for b16s with mild builds..
unless your goin to port your head, and get u a serious compression bump do not bother goin to stage 2/stage B+ cams...cause u'll just over cam ur motor.
I Follow No One.
9400rpms is offline
Old 09-17-2006, 02:20 PM   #12 (permalink)
Car: 98 integra gsr
thankyou 9400rpm for finding that i though that was right
