B18 with a B16 head
70mm throttle body-Skunk2 Intake Manifold
1000cc Injectors-Eagle rods-CP 9:1 pistons
ACT 12lb flywheel-ACT 6 puck sprung clutch
Quaife LSD-Full Race Traction Bar
Full Race t3/60-1 turbo kit-Ram Horn Manifold
205/60/14 BF Drag Radials
331HP at 13psi Cams and more boost to come
Currently looking for some ITR or CTR cams, PM me if you have them.
For sale or Trade. Thermal catback 2 1/4" exhaust.
Clutchmasters stage 3 kevlar clutch and pressure plate.
I canNOT launch. My car is not set-up to drag. The motor is a 97 JDM B18c with the 4.7 final drive. Motor is stock with intake and 2.5in exhaust.
I constantly cut 2.2 60's and on all my runs I had a TPS sensor pop up at the end of 3rd gear which I've been told draws timing.
I ran multiple 13.9's, 14.0's with the 4.4 final drive at Englishtown. At Atco, I made one pass with the 4.7 and missed 2nd and ran a high 2.1 60ft. Still ran 13.9 at 103ish.
Hope that helps a little. A good driver can probably get my car into the mid to low 13's.
