Old 06-30-2008, 10:38 AM   #1 (permalink)
EnJoiThaRex's Avatar
Car: 1988 CRX SI
Mods: D15B2 w/PM6: pacesetter headers, tanabe 2 1/4 exhaust system, ZC tranmission, B&M short shifter, "Custom Shift Linkage", "aftermarket" intake, "8 yr old" tanabe lowering springs
EnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problem
Thumbs up 2nd Gen JDM vs EDM vs USDM Write up!!!
Hello everyone, first off..PLZ STICKY THISS PLZZ!!!
Second. Unfortunately, there are more than 30 images so i can post no more pics. Please click the links anyway if you still wish to see it.
I have done much research and to make life easier for everyone i thought I'd start a thread on the differences of the '88-'91 EDM and JDM CRX's, and I'll even add some USDM stuff. I will say none of this stuff is my own, obviously, i am just putting it all in 1 thread.
So here we go, from the top!!... PLZ feel free to add and comment.
MODELS (Variations)
All CRXs were made in Japan.Even though our CRXs (USDM) were made in Japan, each country/ market
had it's own variations. So the ones for the US were labeled as USDM, the ones for Europe were EDM, Japan was JDM, etc etc etc.
VIN
1st Character
J= Japan
2nd Character
H = Honda
3rd Character
M = Passenger Car, Built in Japan
4th - 6th Character
ED8 = Civic CRX 1.5L
ED9 = Civic CRX 1.6L
7th Character
3 = "3" Door Hatchback, Manual
4 ="3" Door Hatchback, Auto
8th Character
*5 = (std) Civic CRX Manual seat belt
*5 = (std) '89 Civic CRX Automatic ("passive") seat belt
*6 = HF Civic CRX Manual seat belt
*6 = Si Civic CRX Manual seat belt
*6 = Si '89 Civic CRX Automatic ("passive") seat belt
* Passive and Manual were only used in 87-89
9th Character
Unique ?
10 character
J = 1988
K = 1989
L = 1990
M = 1991
11th Character
S = Suzuka, Japan
12 - 17th Character is the serial
European models did not have emission numbers in their engine serial numbers
Emissions - US
40-CA
43- 49 states
49- HF High Altitude
Side note-
ED8- STD or HF (USDM)
ED9 - USDM Si, 1-6i EDM (With/Without Cat)
EE8- 1.6-VT (EDM)
EF6 - 1.5 (JDM)
EF7-Si/ZC (JDM)
EF8 - SiR (JDM)
The Engines
US. Motors (Badges: slowest to fastest - HF, STD or DX, Si)
(STD)D15B2 1.5 16V SOHC PGM-FI 1493 92hp@6000rpm 89tq@4500rpm '88-'91 Civic/CRX DX/LX
D15B6 1.5 8V SOHC PGM-FI 1493 62hp@4500rpm 83tq@3000rpm '88-'89 Civic/CRX HF
D15B6 1.5 8V SOHC PGM-FI 1493 70hp@4500rpm 83tq@3000rpm '90-'91 Civic/CRX HF
D16A6- 1.6L SOHC 88-91 Civic Si/ CRX Si (108hp)
JDM Motors (1.5, Si or ZC, Si-R)
ZC is the badge of the JDM ZC. Serial # below stamp: starts with 2 means its from a Civic/CRX
3rd gen DOHC ZC - black valve cover - came in 88-91 JDM CRX Si and Civic Si
D16A9 1.6 16V DOHC PGM-FI 1595 137hp@6800rpm 108tq@5700rpm '88-'91 Civic/CRX Si (JDM)
B16A- JDM 1.6L DOHC VTEC- 89-91 CRX Si-R (157hp)
D15B - SOHC twin carb- 90hp
EDM ( JDM DOHC ZCs, are the same as EDM D16Z5,A9)
(EE8)B16A(1)-DOHC VTEC (1-6i-VT) Honda CRX 1.6i/VT 1989-1992
(ED9)D16A9 -(No Cat) (1-6i-16) - DOHC - 130 hp (88-89 Civic/CRX)
(ED9) ^^SAME^^ w/ cat -D16Z5 DOHC (1-6i-16) - 124hp (89-92) CRX
ECU's
1989 D15B JDM CRX 1.5X SOHC ECU - PM4
1990 and onwards had a revised ECU, a 1991 model has an ECU model (37700-PM4-914). The 1990 onwards ecu's seem to run a lot smoother, the Rev Limiter seems less severe as well. However they do seen to have less torque low down the rev range.
1990 D16A6 US CRX 1.6L SOHC ECU - PM6
1989 D16A9 EURO CRX 1.6i-16 DOHC- PM7
1988 ZC JDM CRX SiR DOHC - PM7
1990 ZC JDM PM7
1990 and onwards also had a revised ECU, The revisions mainly effect fueling at low revs. There is a slight lack of torque but the whole rev band is a lot smoother. The rev limiter was also revised, early 88 ECU's had a very servere rev limiter.
Interior
Gauge cluster
EDM -Redlines- (Vt:8k, 16:72K)
(90+Vt Cluster)
(88-89 Cluster)
JDM-Redlines -(SiR:8k, 1.5: 7k, ZC or SI: 72K)
(1.5)
(ZC or Si)
(SiR)
USDM
Redlines 6.5k
Seats
EDM Vt- (Vt: Red VTEC Stitching)
JDM - (Si-R: Red Vtec Stiching)
(SiR)
(90+1.5 and Si)
USDM -(Pin stripe varies from years)
(90-91)
JDM (Back Seats)
ImageShack - Hosting :: backseatmp6.jpg
EDM
(Back seats, Leather)
USDM
- (Not an option)
N/A
Climate Control
JDM
(1.5)
(88-89 Si)
Flip up cover and a small dial
EDM-(Same as MY US model, most of them were not AC equipped)
USDM
(My CRX does not have A/C..but on the rightt of the FOG symbol is where the button would be) (HINT**SEE JDM**)
Exterior
Glass top
JDM
ImageShack - Hosting :: exingltophv5.jpg (Limited edition)
EDM
N/A
USDM
N/A
Rear
JDM (1.5: spoilers not standard. Si: raised spoiler. SiR: Raised spoiler w/ center support)
(Si)
(SiR)ImageShack - Hosting :: vtspoileroj9.jpg
[B
EDM[/b]-(Only models where the badges were under the brake lights)
(VTI-->)(<--These came with a raised spoiler w/ center support, like JDM SiR)
(1-6i-16--->)(<--These also came with a flush mount spoiler)
USDM
88/89
Hood
JDM
ZC or Si- Bump Downward w/ hump
Si-R- Raised Bump
USDM (Bump Downward, no cam gear hump)
EDM
(ED9..Notice the bump for the ZC DOHC..like JDM)
(EE8...Not sure about the Kit thought, or the two bumps on the hood, probably like fake scoops)
Front Bumper
JDM (Notice the clear corners and wrap around amber bumper lights..but some of these clips, like the 1 pictured, do not come with the JDM fog lights)(90-92 Shown) (88-89 look like US model)
USDM
88-89
90-91
EDM
Fenders (look as though USDM were the only ones without Side markers.)
JDM (Same as EDM)
EDM
USDM(
Not an option)
N/A
Links...MANY
JDM CR-X Resource (<--Even more Specific in some areas.**SEE HERE FOR LIMITED EDITION MODELS**)
WANT THAT JDM LOOK??!!
Heres a few write-ups i found. I wont post them in the thread because it will make this ridiculously long, but it is here if anyone wants them
1) Honda-Tech.com: Honda CRX / EF Civic: How To: JDM EF Fogs on USDM Front
2) http://*******************/TJForum/h...demarkers.html (Fender Side markers)
3) (May not be good, you'll see why..only posting it this if you swapped your gauge cluster and want the correct mileage..DON'T BE A FRAUD)Honda-Tech.com: Honda CRX / EF Civic: HOW-TO: Setting your Odometer to it's proper mileage. (PICS DONT WORK..play with yours and you will get an idea)
4) http://www.angelfire.com/ca/DrOhm/SiRcluster.html
5) (Sry, no pics in this one..But has hood latch install as well)JDM CRX Front End Info - JDM Universe.com
RICER -drive it like ya stole it
Technicians -drive like ya built it!!
EnJoiThaRex is offline
Old 06-30-2008, 11:14 AM   #2 (permalink)
hndacvcsi's Avatar
Car: 97 civic dx
Mods: coilovers 3" exhaust, shorty intake, built bottom end, more to come!!!
hndacvcsi needs rep therapyhndacvcsi needs rep therapyhndacvcsi needs rep therapyhndacvcsi needs rep therapyhndacvcsi needs rep therapyhndacvcsi needs rep therapyhndacvcsi needs rep therapyhndacvcsi needs rep therapyhndacvcsi needs rep therapyhndacvcsi needs rep therapyhndacvcsi needs rep therapy
that is a very thourough and well informed post. its nice to see people on here that are dedicated to helping everyone else even though they realize they will get critisized for it.
i have just one revision. the glass top is not just a jdm piece. it only came on the cyber crx and is extremely rare. finding one is a once in a blue moon thing and even if you do you will pay a grand or more just to get one
Talk not of loud pipes and which wheels spin, but rather of speed and respect. For when the deed is done, and pride lay wasted on the ground,you will remember the day when you were beaten by the "4-banger"
hndacvcsi is offline
Old 06-30-2008, 11:36 AM   #3 (permalink)
Car: 1988 CRX SI
Thanks, i will fix it after work
Old 06-30-2008, 03:12 PM   #4 (permalink)
drummingpariah's Avatar
Car: 1973 Datsun 240z
Mods: Chevy v8.
drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?
You just got uber-repped by me.
Good luck.
drummingpariah is offline
Old 06-30-2008, 04:41 PM   #5 (permalink)
anassa's Avatar
Car: 85 CRX DX
anassa Why haven't you checked into rep rehab yet?anassa Why haven't you checked into rep rehab yet?anassa Why haven't you checked into rep rehab yet?anassa Why haven't you checked into rep rehab yet?anassa Why haven't you checked into rep rehab yet?anassa Why haven't you checked into rep rehab yet?anassa Why haven't you checked into rep rehab yet?anassa Why haven't you checked into rep rehab yet?anassa Why haven't you checked into rep rehab yet?anassa Why haven't you checked into rep rehab yet?anassa Why haven't you checked into rep rehab yet?
ehh i guess u got repped (gay... can't rep you again yet.), but seriously bump for good info.. and @ sol DO SOMETHING!!!! he does his daily once in a while but he has to start sticking some of the good threads.
THE CAR
- 85 CRX DX
THE PLAN
- get 100whp!
Originally Posted by cbstdscott
Drifting is a conspiracy by the tire industry to get stupid people to buy more tires
- 91 Crx Si (RIP totaled in the canyon on Sept 6,2007)
To meet all your 1st gen needs: RPR
My new hero: Kakabox Index Kakabox Build
anassa is offline
Old 06-30-2008, 04:51 PM   #6 (permalink)
clayton's Avatar
Mods: yes, please.
word.. and between us we probably wield a little rep power.
Originally Posted by B-rex;
clayton is offline
Old 06-30-2008, 09:52 PM   #7 (permalink)
Car: 1988 CRX SI
updated:
-Side Note :Models Section
-Front Bumper: Exterior Section
- Rear: Exterior Section
- Hood: Exterior Section
- EDM Motor: Motors Section
and the work continues...and Thank you for the feedback!!
Old 07-01-2008, 08:17 AM   #8 (permalink)
Car: 1988 CRX SI
Updated:
- Climate Control: Interior
- Fenders: Exterior
- Rear : Exterior
- Seats/Back Seats: Interior
Old 07-01-2008, 08:52 AM   #9 (permalink)
Mods: Chevy v8.
keep up the good work man!
Good luck.
Old 07-06-2008, 11:17 PM   #10 (permalink)
Car: 1988 CRX SI
Updates
-EDM Gauge Cluster, JDM Gauge Cluster: Interior
- EDM Seats, JDM Seat and Backseats: Interior
-JDM Climate Controls: Interior
-JDM Glass Top: Exterior
-JDM Rear, EDM Rear: Exterior
- JDM ZC Hood, USDM Hood: Exterior
- Link
again, links work so click and enjoy.
BE SURE TO CHECK OUT THE LIMITED EDITIONS IN THE LINK I GAVE!! THEY ARE SICK!!
Old 07-07-2008, 07:34 PM   #11 (permalink)
Car: 1988 CRX SI
Well folks, my work here is done. With the addition of "WANT THAT JDM LOOK" I have maxed out in images, as well as characters. So if i find any more info i will unfortunately have to post it elsewhere in the thread. Still STICKY THOUGH!!!(after 12 hours of research and formatting, i mean come on). Feel free to respond to any info.
Old 07-25-2008, 08:28 PM   #12 (permalink)
Car: 1988 CRX SI
Aww Yuu no likey. I make long write up so you no sticky.BBBWWWAAAHHHH!!!
So lets just whore this thread out with some other market info or anything related at all.
Ill start..
So the civic VTi is JDM, yet the Vti CRX is EDM. That seems strange. JDM VTI is where the d15b is from, so it is not even like the EDM VTI.
Technicians
