Mods: JE plug wires, AEM cold air, exhaust, rims, fog lights, clear corners, white gauge faces, rear brake conversion, cross drilled rotors, adjustable coil-overs
actually i don't the crx ever had 5 lugs. i believe the 90-93 integra type-r had them though. the suspension is same just swap hubs.on the front the hub will swap and on the back the best move would be to get rear trailing and hub together.
if you have a b series engine, then you will have the b series axles then you can put on the ITR or CTR hubs and rotors and have 5 lug's..... I am not sure but i dont think you can put the ITR or CTR hubs and rotors on a D Series Axle.......
__________________ 88 DX Hatch SOLD!
90 Si Hatch:
- AEM CAI
- Brembo Cross Drilled Cadmium Plated Rotors
- AEM/Nissin Ceramic Brake Pads SUCK! Dont get em!
- Axxis Metal Master Pads Currently Installed
- Tockiko Blue Shocks
- Eibach SportLine Kit Springs (1.7" Drop, but settled to like 2.5")
- Exedy Clutch (69% Capacity Increase) This Clutch is AWSOME!
- Hybrid Tranny (ZC tranny with ZC gears, but with SI Final Drive)
- 16" Primax 077 (205/40/16)
- Skunk2 Short Shifter w/ Skunk2 Shift Knob & Neuspeed Bushings
- Teg Console
Big UP to my Crew on Long Island, H.R.C. Official 4th Gen OG
Well you can do it by using type r brakes I have the Brakes off of a Type R that I might be selling preety soon. Its the two rear trailing arms and the front shock assemblies
"Instinct is faster than fear..."
2006 Sti Stock for now.
