Old 08-05-2002, 11:48 PM   #1 (permalink)
Car: 1991 Crx si
crx4life2002 is an unknown quantity at this point
tech wrench 5 psi for a built d16a6? any advice on the setup?
i am debating setting up my d16a6 for turbo. im looking to boost at 5 or 6 psi and plan on intercooling it. i have a b&m fuel pressure regulator as well as port polish 5 angle valve job shaved .40 for compression at 11 to 1 chipped ecu jg throttle body headr back intake and 1.8 ls injectors. should i build my lower end for just 5or 6 psi or am i safe to boost away
i think the 1.8 injectors will flow enough and i can richen it with the fpr. do i need a vortech fmu? any advice would be helpful. all motor just doesnt do it for me anymore. thx
crx4life2002 is offline
Old 08-06-2002, 12:24 AM   #2 (permalink)
Honda_Guy's Avatar
Car: '68 Mustang notchback, '84 Mustang SVO
Mods: More than can feasibly fit on this line
Honda_Guy is infamous around these partsHonda_Guy is infamous around these partsHonda_Guy is infamous around these partsHonda_Guy is infamous around these partsHonda_Guy is infamous around these partsHonda_Guy is infamous around these partsHonda_Guy is infamous around these partsHonda_Guy is infamous around these partsHonda_Guy is infamous around these partsHonda_Guy is infamous around these partsHonda_Guy is infamous around these parts
Is this going to be a street car? Because if it is, you'll be in trouble already. 11:1 compression is going to be really pushing it on pump gas, and thats without the boost. Dont mill the head any more than necessary to make it flat. If all you want is 5-6psi, then the stock bottom end should take it. 5-6psi doesnt even really need an intercooler, but it will help make things extra safe. I dunno about the fuel stuff.
1968 Mustang Notchback-Roller cam 302, Edelbrock 60379s, Hooker Comps, Crane 2031, Duraspark, forged pistons, Weiand X-Celerator, Holley 650DP, Fidanza AL fly, RAM clutch, Toploader, Comp Plus, McLeod bell, Mopar 15x7s.
1984 Mustang SVO- stock with Koni susp. & 2.3L turbo with an underrated 175hp/215tq.
'95 XR600R-yoshi header/muff, 200W stator.
Honda_Guy is offline
Old 08-06-2002, 07:58 AM   #3 (permalink)
Car: PIZZA HUT delivery....oh yeah
PSIKOTICsi is an unknown quantity at this point
the b18a injectors wont help any because they flow the same as the d16a6 injectors(240cc). you are gonna need a fmu because what ekse is gonna be adding the fuel needs for a turbo setup. 11:1 cr isnt gonna help you any......the lower the compression the better for turbocharging. your stock bottom end can handle 5-6 psi.
been a member of SHO since aug 99'...my old sn for all the old school SHO peeps...PSRcrxZC
old cars:
93 Ford Probe GT w/ custom RX-7 veilside kit (Team POORSPORTS san diego)
89 Honda CRX si w/ sohc ZC T3 super60 boosted
-2005 white SCION XB w/ 18" Pinnacle Octane wheels
-90 dx htbk for sale as a shell...inquire within
PSIKOTICsi is offline
Old 08-06-2002, 08:20 AM   #4 (permalink)
Car: 1991 CRX Si
Mods: DOHC ZC
crxrocks is an unknown quantity at this point
But, can the stock bottom end support 5-6psi at 11:1?
Chris
1991 CRX Si
Built DOHC ZC
Zdyne Gold SECU
My In progress Turbo Setup HERE
Useful ZC Information!!! Click Me!
crxrocks is offline
Old 08-06-2002, 09:54 AM   #5 (permalink)
5gencivic has a brilliant future5gencivic has a brilliant future5gencivic has a brilliant future5gencivic has a brilliant future5gencivic has a brilliant future5gencivic has a brilliant future5gencivic has a brilliant future5gencivic has a brilliant future5gencivic has a brilliant future5gencivic has a brilliant future5gencivic has a brilliant future
Chris
in theory or the real world?
in theory yes you could make it work... in the real world... street conditions, gasoline quality and tuning will say anywhere from probably not to no.
so i'd get a stock head and then try this...
5gencivic is offline
Old 08-06-2002, 03:57 PM   #6 (permalink)
Car: 1988 s/c crx, 1991 civic si
crxcel is an unknown quantity at this point
I have a jrsc with 9.5:1 compression and it already has detonation problems so I can imagine what 11:1 would do to it. Without race gas i say a meltdown.
crxcel is offline
Old 08-06-2002, 05:13 PM   #7 (permalink)
Car: 92 Honda Prelude Si
Mods: Stock
skidtron89 is an unknown quantity at this point
I totally believe you but that is mostly due to the in-efficiency of the supercharger compared to a turbocharger. He could probably get away with 10.0:1 but much higher than that is gonna take more tuning parts than the whole cars worth. BTW like the guy above said just get a stock head and then you can run 8psi if your careful......
skidtron89 is offline
Old 08-07-2002, 12:44 AM   #8 (permalink)
Car: 1991 Crx si
what if i run 2 head gasketrs to make up for the .40 i shaved off the head to drop the compression to almost stock level? is this kosher or should i re work my stock head for the boost
Old 08-07-2002, 04:31 AM   #9 (permalink)
Honda_Guy's Avatar
Not the best idea to run 2 gaskets. Perhaps you could get an extra thick metal one or something, but ideally you start out with a stock height(unmilled) head.
Old 08-07-2002, 05:12 AM   #10 (permalink)
if you're having problems with your supercharger boosting on a 9.5:1 compression ratio then it's a fuel problem or something else. you should ask a question listing your mods and psi as well as the conditionn of the car and they'll beable to help you out.
two head gaskets or even a thicker metal headgasket is not a good idea in my opinion. lowering compression with gaskets is a good way to get gaskets to fail. you are essentially adding a larger ammount of area for the pressure inside the combustion chamber to push on. the thicker that area is the more it can push the more likely the gasket to fail.
i'd start looking on ebay and find yourself a good stock head. get a valve job and port job done on that and then swap heads out when you install the turbocharger. shouldn't be much of a problem just a bit more time.
to answer your original question more clearly... can you run a turbo on 11:1 compression ratio? yes you can, however it will take a good long dyno session and a fat wallet to provide all the fuel mods you will need to accomplish this goal. also the stock internals of your motor are alreaedy being pushed past what they normally take... adding boost ontop of that stresses them even more.
Old 08-07-2002, 09:05 AM   #11 (permalink)
Mods: Stock
5gencivic says it all right there.........
just not in the usual a-hole way I would though. I think the guy on the other post is still crying about my talking ZC motor reply.
Old 08-07-2002, 01:15 PM   #12 (permalink)
what does your car run in the quarter SKid
crxcel is offline
