Old 07-12-2008, 04:16 PM   #1 (permalink)
pdx.cervix is on a distinguished road
87 Si, won't start, was fine.
87 Si, 217K miles, fuel inj/elec ignition.
Was running perfectly on a hot day. went down block
turned off, tried to restart 10 min later, nothing. cranks &
cranks & cranks.
New plugs, spark seems fine on all 4 (held plug to car groudn with
plugwire attached, got spark), has compression (155 all cyl), resoldered
main relay & tested per crappy chilton's manual, is ok. no pGMFI/Engine
light coming on, saw no engined fuses underhood, all fuses underdash
just fine, no lights blinking on ECU, fuel pump whirrs, got the right amount of
fuel when disconnect return line & filled bottle for 10 sec. I'm assuming
its fuel related somehow?? Look visually @ timing belt,seems just fine, fiddled
with timing by moving distributor back & forth. checked rotor & cap, seems ok. I removed the distributor, & it seems ok.
Any suggestions? I cranked engined & removed plug, not sure if plug is wet
enuf or what the #%!?? I dunno, hate to go replacing distributor, ignitor & lots of other crap, w/o knowing what's wrong. Don't have a friend that has the same car either.
Thanks if anyone has suggestions on what to try.
pdx.cervix is offline
Old 07-19-2008, 01:25 PM   #2 (permalink)
Joewill2848's Avatar
Car: 89 crx si
Mods: 17" wheels cat back exaust black halo headlights black corner lights clear marker lights blck rcing seats 4 point harnesses spoon sports steering wheel blacked out windows strut tower bar skunk2 shift nob complete energy suspension bushing kit energy suspension mtr mnts white face gauges body kit fresh red paint battery discnect swtch lambodoors
Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848
have you tried checking the ecu out i have heard og this probelm and it being the ecu before give that a try i know it might be hard to locate and ecu but if you can try hooking it up to your car and cranking it
on my 14th car and i doubt the madness stops here
Joewill2848 is offline
Old 07-19-2008, 03:56 PM   #3 (permalink)
GunMetal Member
jordan_myers's Avatar
Car: 1990 CRX; 1996 Chevy Balzer
Mods: Rebuilt B18A1 with replacement oem rods, pistons, rings, a port and polished head, replacement valves, valve angling, dual valve springs, STR cams, Edlebrock intake manifold, custom cold air intake, Chikara header, custom-welded 3" exhaust; limited-slip differential, double plate clutch, short-throw shifter.
jordan_myers Why haven't you checked into rep rehab yet?jordan_myers Why haven't you checked into rep rehab yet?jordan_myers Why haven't you checked into rep rehab yet?jordan_myers Why haven't you checked into rep rehab yet?jordan_myers Why haven't you checked into rep rehab yet?jordan_myers Why haven't you checked into rep rehab yet?jordan_myers Why haven't you checked into rep rehab yet?jordan_myers Why haven't you checked into rep rehab yet?jordan_myers Why haven't you checked into rep rehab yet?jordan_myers Why haven't you checked into rep rehab yet?jordan_myers Why haven't you checked into rep rehab yet?
First do you have a manual? If so have you tried to "bump start" your vehicle? I should hope that you know what I'm talking about, but in the event that you do not (which by your previous post the amount of knowledge of cars was evident so I do not think you need this explained, but in the event you haven't heard of this I'll go into it) a "bump start" is simply getting your vehicle to a roll in neutral then shifting into first and "dumping" or releasing the clutch....
Second, have you tried checking your fuel filter? It could be a clog in the filter. In order to check this you would simply remove the fuel line going from the filter to the engine, and turn your key to start the fuel pump. If fuel comes out the filter is good, if not then it is clogged and needs replaced.
Third, you had mentioned some thing about the ECU in your post. So I take it that you have the led for any flashing or error codes..If not you may want to do this. Also you could unhook your battery for a short time period and reset the ECU which may also fix your problem.
Hopefully I have been of some help, if not well I'm sorry I couldn't help you further....I also hope that you get this problem resolved.
Last edited by jordan_myers : 07-19-2008 at 03:57 PM. Reason: I seen that he had checked for blinking DDDUUUURRRR
jordan_myers is online now
Old 07-19-2008, 05:12 PM   #4 (permalink)
MR. 87 HONDA's Avatar
Car: 1987 honda crx
MR. 87 HONDA is infamous around these partsMR. 87 HONDA is infamous around these partsMR. 87 HONDA is infamous around these partsMR. 87 HONDA is infamous around these partsMR. 87 HONDA is infamous around these partsMR. 87 HONDA is infamous around these partsMR. 87 HONDA is infamous around these partsMR. 87 HONDA is infamous around these partsMR. 87 HONDA is infamous around these partsMR. 87 HONDA is infamous around these partsMR. 87 HONDA is infamous around these parts
ah wut up man got a 87 si my self checkthe wiring maybe touching or the ecu for sure man !!
MR. 87 HONDA is offline
» Site Navigation
» Home
 > FAQ
» Other Sites
