you will need,
engine
tranny (assuming its a cable one)
axles
ecu
you will have to have your shift linkage shortened or buy aftermarket
aftermarket motor mounts ( hasport, place racing etc )
you will also have to wire your car to MPFI, which means you need injectors, injector plugs, resistor box
that is all I can think of at the moment. Good Luck
