Old 06-24-2004, 09:00 AM   #1 (permalink)
Car: 90 CRX Si
Mods: Mini-me w/ D16A block/ Z6 head. Exedy stage 1 racing clutch. Fidenza lightened flywheel. AEM CAI. VAFC. More to come...
Dub N Rex is infamous around these partsDub N Rex is infamous around these partsDub N Rex is infamous around these partsDub N Rex is infamous around these partsDub N Rex is infamous around these partsDub N Rex is infamous around these partsDub N Rex is infamous around these partsDub N Rex is infamous around these partsDub N Rex is infamous around these partsDub N Rex is infamous around these partsDub N Rex is infamous around these parts
90' DX engine swap questions...
Hey guys, new to the forum here and have some questions for ya...
I was set on getting my DOHC ZC and swapping into my DX but just recently found what looked like a damn good price on a b18b1 with auto tranny(would probably sell the tranny and try to find a manual). The engine has 70k miles and for bother the engine and tranny is $500. I would have to pick up like 8 hours away so I wouldn't really be able to inspect either. Well here's where the kicker is...
I already have a lightened ZC flywheel (got a good price on it), the pg7 ECU and a hydro tranny set up (I think the b18 is cable?) so this would probably be money in the hole until sold. With the engine and tranny for the b18 being pretty cheap do you think I could still stay around $1000+ for everything on the swap (ECU, perfomance clutch, flywheel, axles, etc.). That is what I was looking at for the ZC swap.
Also, if it is extra money, would it be worth it for dependability and every now and then a little street racin'?
One last question: I thought I knew what I was looking for for tranny wise on the ZC but someone threw me a curve ball. I was told I either need a true ZC tranny or a 88-91 Si Tranny. What was also said was SI Tranny with ZC 3-4- and Si 5. What is needed to do a 'hybrid' tranny? Can you by just the gears? And what tranny will work with the b18b1 to keep my options open.
Anything else I am not taking into consideration? :?
Thanks guys!!!!!
Dub N Rex is offline
Old 06-24-2004, 01:47 PM   #2 (permalink)
Car: 1991 CRX HF
Mods: Wings West Body Kit, Nuespeed Short Shifter, AEM Intake, Tokico Illuminas, Pioneer head unit, 2 alpine subs, and apline amp. Future plans are to get a B16A1 swap and turbo.
RicerGSX will become famous soon enoughRicerGSX will become famous soon enough
Well if you have already started preparing for the ZC swap and buying parts for it I think that you should stick to it. At least I would if I were you. As for the B18 deal. If its coming with an auto tranny that would put you through more trouble trying to afford the manual one. If its worth it to you then go for it. I would stay with the ZC though.
1991 CRX HF (My POS Attempt)
Tokico Illuminas
AEM Short Ram Intake
Neuspeed Short Throw Shifter
Custom Exhaust
Hasport Mounts
Hasport Shiftlinkage
Wings West RS Body Kit
Alpine Sound System
Pioneer Head Unit
My Car
Team Eyeless Performance/Audio (coming soon)
SHO OWNZ ME!
RicerGSX is offline
Old 06-24-2004, 02:49 PM   #3 (permalink)
Car: 1990 Honda CRX HF
Mods: d16a6
Moon Ill has much to be proud ofMoon Ill has much to be proud ofMoon Ill has much to be proud ofMoon Ill has much to be proud ofMoon Ill has much to be proud ofMoon Ill has much to be proud ofMoon Ill has much to be proud ofMoon Ill has much to be proud ofMoon Ill has much to be proud ofMoon Ill has much to be proud of
Why did you have the hydro tranny set-up?
Moon Ill is offline
Old 06-25-2004, 11:04 AM   #4 (permalink)
Car: 90 CRX Si
Because...
I was told by some people that if I were to get a manual tranny, performance wise, the Si would be better. They also said I needed it for 92-95, which is hydraulic. I now know I either need a ZC tranny or a 88-91 cable tranny from and Si. By the way, I think I'm going to stick with the ZC for now and upgrade later when I have more money: a year or so...
Old 06-25-2004, 01:32 PM   #5 (permalink)
Dark Samurai
90Si's Avatar
Car: GTF away thief
Mods: Porsche air filter
90Si you're still here?90Si you're still here?90Si you're still here?90Si you're still here?90Si you're still here?90Si you're still here?90Si you're still here?90Si you're still here?90Si you're still here?90Si you're still here?90Si you're still here?
i would have went with the LS.
90Si is offline
Old 06-26-2004, 01:41 AM   #6 (permalink)
Dark Wind
Car: 1994 Civic EX, 1998 Ranger
Mods: both stock
Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?
they lied although a D series tranny will bolt up the "best" option is to use a ZC/Si hybrid tranny, by that i mean use a ZC tranny, and then swap out the final drive for a Si final drive, but it depends cause when i had my ZC with ZC tranny 5th gear is LINEAR meaning going from 4th to 5th was just like going from 1st to 2nd it stays high RPM and the ZC/Si combo will make it even more linear... it all just depends on if you drive on the highways and dont care if its high revved or not
Anomoly is offline
Old 06-26-2004, 02:56 PM   #7 (permalink)
Car: 1991 Civic HB
Mods: None Yet
WhiteHorseIP is an unknown quantity at this point
which is better?ZC or Si tranny? I am currently running a ZC tranny on a d15b2 Si conversion in my 89 CRX HF. I just bought a complete Si motor from a friend, motor's FUBAR,(for now) as he floated the valves and pistons hit the head. however I got the trans with it and was wondering if I should keep my ZC tranny or use the Si tranny. I am looking for the best acceleration but with a comfortable top gear for highway driving. However I will sacrifice highway driving for acceleration.(anything to make this car go faster till I swap).
WhiteHorseIP is offline
Old 06-26-2004, 02:58 PM   #8 (permalink)
Car: 1991 Civic HB
Mods: None Yet
Also why does my pic not show in my sig just that little red x?
