D series BS.... need info/help
OK..... here's the deal. It's a SOHC ZC block with a D16a6 head on it.... after a long list of problems (swap was obviously doomed from the start) finally got everything in an bolted up. Go to put the timing belt over the cam gear and tighten it down..... and after the adjuster was FULLY tightened, the front side of the belt was completely loose. I mean ya could just wiggle it about an inch back and forth. I've adjusted the tensioner and everything, and the only thing I can think of is replacing the timing belt. Has anyone done this swap? I mean, the SOHC ZC and the USDM D16a6 are almost identical, correct? I measured the head height and they are both the same. The cam gears are the same size..... I can't think of what the hell the problem is. Apparently it worked fine with the ZC head on it, but I decided to not use that head because it *might* have a bent valve or something (right mario?) either way, is the SOHC ZC t-belt longer than the a6 belt? If anyones got any ideas, I'd appreciate the help. OR else I h\guess I'll just have to pull that valve an stick the ZC head back on, swap out the cam, etc.... either way I've gotta get it back on the road tonight.
Maaan.... this is why I usually dont mess with D series swaps bad luck
Member Since '01. Old-Skool, Bitches.
1989 DOHC VTEC CRX Si -Sold!!!
1988 SOHC ZC CRX Si -Scrapped
1999 Dodge Dakota R/T -For Sale
2000 VW Jetta GL -Virgin.... for now
