Old 12-12-2006, 07:08 AM   #1 (permalink)
Black89CRXSi's Avatar
Black89CRXSi is on a distinguished road
Downgrading !!!!
PLease help me...I have a 91 CRX with a JDM B16a swap with a PW0 ECU... I have recently decided to downgrade...I am wanting to go back to a SOHC motor so i can run in my stock AutoX class... I am debating between a D16A6, D16Z6, or building a Mini Me Motor... Does anyone here have any idea what it would cost me to do the switch ??? I did not put the B16 in the CRX I bought it with it in it already. I would love to have a Vtec motor still...and yes i know that the A6 is not a Vtec...
All i deas are welcome...and no i do not want to stay b16 so dont suggest that...(i know it is retarded to drop back to a SOHC from a DOHC)
91 CRX DX
Champ White
JDM SiR B16 Swap (Down For The Count )
PW0 Ecu
4-2-1 Stainless Header
Tenzo R Cat-Back Exhaust
Tokico Blue Shocks and Struts
Skunk2 Coilovers
(Bootsed LS Soon To Come )
Black89CRXSi is offline
Old 12-12-2006, 10:14 AM   #2 (permalink)
RockinthEFhatch's Avatar
Car: 1991 CRX Si
Mods: 1991 CRX Si, Tahitian Green Pearl, B16A / Spoon Sports Flywheel / Spoon Sports VTEC controller / Exedy stage 2 clutch / B&M shifter / HyTech header / RS*R ExMag exhaust / Akimoto Intake / Progress Competetion Coilovers / Axxis Ultimate brake pads / BFG KDW2 tires / GSR wheels /
RockinthEFhatch is infamous around these partsRockinthEFhatch is infamous around these partsRockinthEFhatch is infamous around these partsRockinthEFhatch is infamous around these partsRockinthEFhatch is infamous around these partsRockinthEFhatch is infamous around these partsRockinthEFhatch is infamous around these partsRockinthEFhatch is infamous around these partsRockinthEFhatch is infamous around these partsRockinthEFhatch is infamous around these partsRockinthEFhatch is infamous around these parts
You have no idea how sad you will be... What you should really do is buy a Spoon VTEC controller! I have one for sale if you want, and it's OBD-0!
RockinthEFhatch is offline
Old 12-12-2006, 12:28 PM   #3 (permalink)
I know there will be a definate difference...but i cant run in my "STOCK" class in AutoX with a B16 since they did not come factory in the CRX in the USA...i dont use this car for "STREET" or "DRAG" so the bigger motor doesnt matter to me...in AutoX "Bigger" is not always "Better" it is about driver skill and consistant times...i am not competitive in the current class i am in which is a modified class...i dont think i will be "sad" at all...i will have exactly what i want. Besides...I am getting tore apart by a 110% STOCK 89 CRX SI with a D16A6 with the same suspension setup i have....
91 CRX DX
Champ White
PW0 Ecu
Skunk2 Coilovers
Old 12-12-2006, 12:42 PM   #4 (permalink)
Car: 88 `':..:'`c]2x`':..:'`
88ReX is infamous around these parts88ReX is infamous around these parts88ReX is infamous around these parts88ReX is infamous around these parts88ReX is infamous around these parts88ReX is infamous around these parts88ReX is infamous around these parts88ReX is infamous around these parts88ReX is infamous around these parts88ReX is infamous around these parts88ReX is infamous around these parts
I would go with the a6 it's plenty of power for autox....I think that the z6 would probably still put you in a modified class and the mini-me would for sure, you have to match the head and block if I remember right (but its not like the techs know anything).
88ReX is offline
Old 12-12-2006, 12:52 PM   #5 (permalink)
yeah you are right... i am reading over the rulebook right now and i think it will have to be an A6...The SCCA Chapter that i am in will let me run the Z6 in my stock class...but i cant run nationals with it...so i think that an A6 would be just fine.
91 CRX DX
Champ White
PW0 Ecu
Skunk2 Coilovers
Old 12-12-2006, 02:12 PM   #6 (permalink)
solsykness's Avatar
Car: '93 Del Sol SI
Mods: check out my sig bish!
solsykness you're still here?solsykness you're still here?solsykness you're still here?solsykness you're still here?solsykness you're still here?solsykness you're still here?solsykness you're still here?solsykness you're still here?solsykness you're still here?solsykness you're still here?solsykness you're still here?
I guess you got it all figured out then huh? :clap sucks you can't run the z6 in nationals. I think the z6 is the better sohc motor. I've had two in my past del sols. you should be able to find a swap, or all the parts you will need for fairly cheap.
99 EJ8
Coupes FTMFW
solsykness is offline
Old 12-12-2006, 04:11 PM   #7 (permalink)
ksniperfox's Avatar
Car: 90 rex si
Mods: JR edition GT killer
visit www.exospeed.com for a race d16a6 NA, if you can afford it.
'90 crx Si
MY VIDEO(old setup)
Originally Posted by Snoopy
ksniperfox is offline
Old 12-12-2006, 06:24 PM   #8 (permalink)
i agree...i wish i could run a Z6 but they didnt come in the REX. (which is why i cant run it)
91 CRX DX
Champ White
PW0 Ecu
Skunk2 Coilovers
Old 12-13-2006, 11:42 PM   #9 (permalink)
ataris2 is on a distinguished road
i have an a6 that i am looking to get rid of it is disasembled let me know if you are interested
if at first you dont succeed, destroy any evidence you ever tried.
ataris2 is offline
Old 12-16-2006, 03:02 AM   #10 (permalink)
Car: 90 Crx Si
ProjectZC is an unknown quantity at this point
I think its a great idea. I love the SOHC. yes the b16 is better. But there is someting to be said for a well built SOHC. The a6 is a very strong motor and will take alot of abuse. Add some internal upgrades port polish balance etc.... And and A6 will give you a run for your money. I am currently working on building one. I know you can't modify the engine that much in a stock class but if you put lets say 88-89 integra pistons in one you get an extra .1 of CR and a few extra ponies. The rods are stronger too. Good luck Auto x is fun I wish I could afford to do it.
90 CRX Si D series
RS-R, Momo, C's, Tein, KYB
88 LX Sedan DOHC ZC
Mugen, JDM Conversion
Suspension Tech, KYB
00' Civic Si
AEM, Apexi VAFC
ProjectZC is offline
