How to install a fuel pump for 91 crx? - Honda Forum : Honda and Acura Car Forums
Ľ Wheel & Tire Center
Go Back   Honda Forum : Honda and Acura Car Forums > Honda - Vehicles > Honda Vehicle Models > CRX Forum
Old 04-26-2004, 11:32 AM   #1 (permalink)
Car: crx si
lazykiwi is on a distinguished road
My car is not starting up!! So i'm planning to install the starter tonite and if that don't won't than i'm going to try to install the fuel pump. Anyone know how to install it? THANK
lazykiwi is offline
Old 04-26-2004, 11:34 AM   #2 (permalink)
Car: 89 crx
Mods: lowered
smallracer2 is an unknown quantity at this point
Fuel pump is in the gas tank........
smallracer2 is offline
Old 04-26-2004, 01:30 PM   #3 (permalink)
Car: crx si
Can i get to it!! under the seat?
lazykiwi is offline
Old 04-26-2004, 01:46 PM   #4 (permalink)
CRXican is on a distinguished road
lol it's behind you, under the cargo thingy, right in the middle.
CRXican is offline
Old 04-26-2004, 03:51 PM   #5 (permalink)
bboylooney is an unknown quantity at this point
yea..there is a secret vtec switch under the seat also...find it...turn it on..and you've got 30hp!!!
bboylooney is offline
Old 04-26-2004, 10:05 PM   #6 (permalink)
Rev ATARI's Avatar
Mods: Ending Corporate SHO Member #1
Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?Rev ATARI Why haven't you checked into rep rehab yet?
You have to drop the fuel tank, itís a bitch to do. Why donít you check to see if your getting fuel before you try replacing it? All you have to do is crank the engine some then pull a plug and smell. If you smell gas its not the fuel pump
Every time you post on SHO, Jesus rapes a child
Rev ATARI is offline
Old 04-26-2004, 10:44 PM   #7 (permalink)
Car: '95 Civic '91 CRX SiR
Mods: too many to list.. and no one cares anyway
ol'skoolrex_PH is an unknown quantity at this point
either that or use a 12mm wrench and release the pressure from the pressure release nut on top of the fuel filter.. be sure to use a rag - also, once you have a dry tank for a while or if your engine has been sitting.. you need to prime the fuel lines with fuel.. meaning you just need to turn the key to the on part (not start) you'll hear the fuel pump come on for a sec to build up pressure. then turn the key off and repeat. once you do that a few times, your motor should start right up.
also you gotta drop the tank..I think you can get to it if you remove the rear interior panels.. so whatever is easier.
ol'skoolrex_PH is offline
Old 04-27-2004, 09:40 AM   #8 (permalink)
Car: crx si
Last nite. I try to get it from behind the seat but it wasn't there so we had to drop it the tank!! It was such a pain..But the car still dosen't work.
lazykiwi is offline
Old 04-30-2004, 06:22 AM   #9 (permalink)
Car: 1988 Honda CRX SiR
Mods: 88 SiR, Blitz combat front bumper, buddy club side skirts, z3 fenders, wings west rear bumper. Euro antenna, Prelude seats, 17 in enkei rims, Short shifter, B16a, custom interior and stereo set up, and still working on everything else.
godspeed18 is an unknown quantity at this point
Is it atleast turning over?
CHeck Dirty fuel filter, bad injectors, car not properly grounded, just some thoughts.
If you don't race then what do you do?
godspeed18 is offline
Old 05-01-2004, 02:41 AM   #10 (permalink)
GunMetal Member
twofacedsir is an unknown quantity at this point
I say check everything at this point, from fuel delivery, spark, firing order, plugs, timing, to what ever you can think of. Pick up a helms manual, and give it a go. Just narrow down all the possibilities.
D' Ichi Roku VTEC Turbo Honda CRX
You want the pics. You want the specs.
Then here it is!
twofacedsir is offline
Old 05-01-2004, 09:29 PM   #11 (permalink)
Car: crx
Mods: crazy stuff
skipper is an unknown quantity at this point
ya dood you probably didnt need to drop the tank,its probably something else thats causing you not to start..get a repair manual with a troubleshooting guide...good luck
skipper is offline
Old 05-01-2004, 09:39 PM   #12 (permalink)
Car: crx si
Just got the fuel pressure gauge today, going to try and check the fuel pressure tommorrow. will keep you guys posted...
lazykiwi is offline
Old 05-01-2004, 10:37 PM   #13 (permalink)
Car: 89 CRX SI with B18a fully rebuilt 0 miles on it
Mods: P&P head 3angle valve job, Compleatly rebuilt.--Turbo set up in the build
CRXsiR84 has a little shameless behaviour in the past
man ur being real dumb bout this and throwin soo much $$ away!! dont just go throwing things at the car hoping that it will fix the prob. try to pin point the prob as best as possabe. for all you know right now it could be a fuse!!! or a melted wire!! does it crank?? if it cranks and just doesnt start.. check the plugs, are they nasty? clean em or replace em, then check for spark, be sure your plug wires are not crossing eachother, it will cause a cyl. to fire when its not spose to, if spark is good, does it have fuel, like they said check the bleader on top of the fuel filter.... id replace the filter ne way cuz those are always neglected, check your battery!! does it have 12+ volts?? are there any blown fuses in the main fuse box, or inside??? ur throwing money away man by throwin parts at it, dont do that. good luck
Tyler
CRXsiR84 is offline
