at the very worst your motor may have some seized parts in the block. if you sprayed it with pb and it freed up, i would suggest putting the swap on hold, and taking the block to be ripped apart, hot tanked, as well as tanking the internals. if not you may get one good fire and snap something inside and then you really are fucked. this could be as simple as a cylinder hone, or complex as needing a slight bore(hence needing new pistons)
 Talk not of loud pipes and which wheels spin, but rather of speed and respect. For when the deed is done, and pride lay wasted on the ground,you will remember the day when you were beaten by the "4-banger"
