Old 06-25-2004, 09:15 PM   #1 (permalink)
Biomechanoid is an unknown quantity at this point
Need some specs on a CRX
Hey all, I'm researching candidates for an LS1 swap, and one of the chassis that looks promising as far as weight goes is the CRX. mainly, what I want to know are 3 things:
1) engine bay dimensions
2) Width of the rear end
3) approximate weight of the stock engine
1 is most important as it's going to tell me the feasability of this project, and 3 is going to tell me how much I need to modify the suspension (my block should weigh in around 280lbs when complete).
in case people are wondering I'm planning on the following setup
Modded LS1 with a t56 tranny linked to a drive shaft and 11 bolt differential from a holden (austrailian GM) Trans Am. Plans for the car is to completely gut it, and chop the frame as needed to install the tranny, and also cut down the axles on the diff to fit the width of the rear wells. the front suspension will be moderately easy as there are plenty of donor CRX's in the 'yards for me to grab pieces to fabricate a functional Front suspension.
as far as specs goes on the engine
LS1 block
Ported "stock heads"
TREX cam kit
LSX intake
38.8lb injectors
Forged crank w/ 383 stroker kit
Hooker headers
Desktop dyno's placing the engine in at 430HP, so this should be a beast in a 1600lb CRX
Biomechanoid is offline
Old 06-25-2004, 09:40 PM   #2 (permalink)
enfield's Avatar
enfield In the rep troposphereenfield In the rep troposphereenfield In the rep troposphereenfield In the rep troposphereenfield In the rep troposphereenfield In the rep troposphereenfield In the rep troposphereenfield In the rep troposphereenfield In the rep troposphereenfield In the rep troposphereenfield In the rep troposphere
please dont butcher a crx
enfield is offline
Old 06-25-2004, 10:43 PM   #3 (permalink)
Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!
I honestly don't think you will be fitting an LS1 longitudinally in the CRX engine bay without serious firewall modification. A B-series engine barely fits transversely, and with a supercharger there is almost zero clearance.
Best of luck to you though, I'd like to see someone actually complete a project like this with an original CRX chassis instead of a tube-frame.
TTT for you; if nobody has the information by tomorrow I will go out with a tape measure and try to get some measurements.
RC38 | RD7 | ED6 | ED9 | EM1 | EJ1
Matta Motors
- The Honda Car People
Targa250R is offline
Old 06-25-2004, 11:25 PM   #4 (permalink)
UltimX is an unknown quantity at this point
3 is about 70 more pounds than what u guessed.
JAPowered
1800 lbs and lighter....
UltimX is offline
Old 06-26-2004, 01:33 AM   #5 (permalink)
Car: 1994 Civic EX, 1998 Ranger
Mods: both stock
Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?
1. it can be done
2. tub it and chop the axle
3. not sue on the weight but me and a friend can easily lift the motor/tranny combo
you cant really chp the frame cause there is no frame its unibody
front suspension, youre gonna need somethign other than stock junkyard parts, but it seems to me youre building a drag car so i dont think you really need to do anything to it, just make sure its stock height
Anomoly is offline
Old 06-26-2004, 02:40 AM   #6 (permalink)
Smile
Originally Posted by SHIFT125R
1. it can be done
yeah, it's a dedicated track car. thanks for all the responses. If the engine bay is close to what I need, the only real problem I'll have is modifying the firewall to fit the belhousing of the T56 to have a clean install.
Old 06-26-2004, 10:39 AM   #7 (permalink)
Car: 1990 Civic Si
Mods: B18A1, Ground Control coilovers, Koni yellows, catback, and god behind the wheel :)
Mattamotor is an unknown quantity at this point
In the current Grassroots motor sports there is a Chevy 350 powered CRX that enter the $2004 dollar challange. It ran 11s, the tire stuck out a good 5 inches on each side(you would need flares to be street legal) and requied a a very good engineiring back ground, expert fabercation skills and way more time than you would expect.
It was in a 86 CRX and built buy Crabill Racing. who are Dennis Crabill,Chad Brodbeck, Joel Barnett, Jerry Schaffer, Jamie Redcay, Brain Keener, Pat Brown. It took them 6 months to build it in York Pa.
I would suggest looking at local to york autocross website and see if you can find these guys e-mail. They might help they might blow you off(i would want to tell someone how i put this thing together). Good luck though a post pics if it ever gets done.
MattaMotors.com
Frost 1990 Civic Si - #21 SM
Paradise 1994 Integra GS-R
"If your not afraid while driving you are not going fast enough"
Mattamotor is offline
