ok im going to get some tires right now but i gotta go look for some around but what i wanted to know is a good size for the civic si's alloy rims from the 99-00 i know i already asked but they said to many diffrent sizes i need only one size that will fit perfect
Mods: 16x7.5 American Racing Vortechs (Federal tires), Weapon R CAI, custom OBX exhaust system (in spring), Tokico blues w/ Tom's Racing coils (in spring), EDM si wing, body restoration project.
The wheels are 15x6.5 I believe, so I'd say 195/45/R15 or 195/50/R15 and they wont rub for sure. 205/50/R15 would be a little better for performance, but they might rub on hardcore cornering.
Mods: stripped, no a/c modded B18c with bigger injectors, Hondata, Toda spec B, 72mm throttle body, USDM Type R tranny with JDM 4.786 final drive, Spec Stage II clutch/pp 8.5lb. FW;Koni/Eibach ERS/GC sleeves susp. w/integra knuckles w/ Type R calipers/rotors, Carbotech 1109s ducted;Kosei K-1 TS w/ r compounds; full custom cage, Sparcos w/ 5 pts., etc.
I run 205/50/15 r compound Kumho V710s and those are wide ass tires for their size. I have a 38mm offset wheel.
Barry H.
88 CRX Si, stripped sub 2000lb., no a/c, modded B18c, hondata, Toda Spec B cams, 72mm throttle body, USDM close ratio tranny with JDM 4.785 final drive, Spec II clutch/pp w/ 8.5lb FW;Koni/Eibach ERS/GC sleeve susp.w/ Integra knuckle w/Type R calipers-rotors w/ carbotech 1109s ducted;full cage w/sparco EVO seats w/5pts; Kosei K-1 TS w/ r compounds, etc. etc.
