Old 10-17-2005, 01:22 PM   #1 (permalink)
S2kpr's Avatar
Car: 2001 S2000
Mods: Get some
S2kpr Um, 1 million? Damn!S2kpr Um, 1 million? Damn!S2kpr Um, 1 million? Damn!S2kpr Um, 1 million? Damn!S2kpr Um, 1 million? Damn!S2kpr Um, 1 million? Damn!S2kpr Um, 1 million? Damn!S2kpr Um, 1 million? Damn!S2kpr Um, 1 million? Damn!S2kpr Um, 1 million? Damn!S2kpr Um, 1 million? Damn!
Rex Wont Start
Hi everyone!
I recently bought an 88 crx si .Yesterday i tried to start it up, but it wont start, it makes a clicking noise when i turn the key,i measured the voltage on the battery and its good.
I also noticed that in the cluster, the check light and the brake light, are dimmer than the others.
Could it be the main relay ? i tried to find it, but i cant
Can someone help me ?
Thank you!
Web Hosting Needed ? Host Rocket Plans For $138.80 2 Years with New Domain!!! Incredible Dont Forget to click on the link below
http://affiliatecenter.hostrocket.co...te.php?id=5735
Wholesale Electronics from Chinavasion , Dont forget to click on the link below!
Click Here : http://www.chinavasion.com/?ref=3574
S2kpr is offline
Old 10-17-2005, 01:23 PM   #2 (permalink)
Olde School Ricer
Car: 89crx
Does it crank over?
Originally Posted by got-vtec?
Would it be safe to go about 180-190 mph on the street in a lightened crx.
yellowrexsi is offline
Old 10-17-2005, 02:29 PM   #3 (permalink)
S2kpr's Avatar
Car: 2001 S2000
Mods: Get some
nope, try to crank it but it wont start
S2kpr is offline
Old 10-17-2005, 02:30 PM   #4 (permalink)
Car: 1989 Honda CRX
SilverCRX2434 is a glorious beacon of lightSilverCRX2434 is a glorious beacon of lightSilverCRX2434 is a glorious beacon of lightSilverCRX2434 is a glorious beacon of lightSilverCRX2434 is a glorious beacon of light
what was the voltage on the battery?
Aim: SaDClowNSe7eN 25
SilverCRX2434 is offline
Old 10-17-2005, 05:52 PM   #5 (permalink)
S2kpr's Avatar
Car: 2001 S2000
Mods: Get some
The voltage on the battery is 13.5v
S2kpr is offline
Old 10-17-2005, 05:57 PM   #6 (permalink)
Olde School Ricer
Car: 89crx
What's the voltage when you go to crank it over
Could be a bad ground.
Old 10-17-2005, 07:21 PM   #7 (permalink)
lude_pwr's Avatar
lude_pwr has a Rep problemlude_pwr has a Rep problemlude_pwr has a Rep problemlude_pwr has a Rep problemlude_pwr has a Rep problemlude_pwr has a Rep problemlude_pwr has a Rep problemlude_pwr has a Rep problemlude_pwr has a Rep problemlude_pwr has a Rep problemlude_pwr has a Rep problem
what i would do is take a test light and test the wire going into the starter solenoid. but before you do that test all the fuses. there are small terminals exposed in the back of the fuses. probe the test light there. if you get no signal AT the starter solenoid. check the relay. have someone try to crank the car over and listen for the relay to click. if no clicky, replace the relay. if you are getting power at end of the starter solenoid circuit. it's probably the starter. if you feel it is you can take a hammer and tap on it while trying to turn the engine. NOTE: there are permanent magnets inside the starter motor that you may break while doing this. you can get your starter rebuilt, buy a rebuilt starter (usually with a core charge of your old starter), or buy one brand new at the cost of your very own left nut. lol, jk. hope i helped good luck.
also make sure you have a good ground when using the test light, test it on the battery for proper operation, then find a bare metal (unpainted) surface. i suggest the tranny or block or motor mount or somewhere. those dim cluster lights are probably just bulbs burning out. easy fix they just twist right out.
patiently gathering the funds for a greater cause
lude_pwr is offline
Old 10-18-2005, 10:50 PM   #8 (permalink)
Car: 1998 Prelude type SH
Mods: AEM intake, eibach pro kit
esp4p3 Hello down there miniscule peonsesp4p3 Hello down there miniscule peonsesp4p3 Hello down there miniscule peonsesp4p3 Hello down there miniscule peonsesp4p3 Hello down there miniscule peonsesp4p3 Hello down there miniscule peonsesp4p3 Hello down there miniscule peonsesp4p3 Hello down there miniscule peonsesp4p3 Hello down there miniscule peonsesp4p3 Hello down there miniscule peonsesp4p3 Hello down there miniscule peons
What about the alternator?
Pearl White
98 prelude type sh
"Napoleon, don't be jealous that I've been chatting online with babes all day. Besides, we both know that I'm training to be a cage fighter. "
esp4p3 is offline
Old 10-19-2005, 11:50 AM   #9 (permalink)
Car: 1990 CRX Si
Mods: www.glasssphere.net/crx
jadkar has a brilliant futurejadkar has a brilliant futurejadkar has a brilliant futurejadkar has a brilliant futurejadkar has a brilliant futurejadkar has a brilliant futurejadkar has a brilliant futurejadkar has a brilliant futurejadkar has a brilliant futurejadkar has a brilliant futurejadkar has a brilliant future
Bingo baby!! Bingo!!
Listen to this dude, I'll put money on the starter solenoid stuck. I bet you the hammer trick will work. It's so easy to try that I would even do this before I tested any circuits. Have someone crank the engine over while you tap the starter solenoid with a hammer (or something long enough to get down there). If this doesn't start the car then test the circuits, if your getting voltage then get a reman'd starter and call it a day
Remember to make sure the car is not in gear...I don't want to hear about some dude getting run over
jadkar is offline
Old 10-19-2005, 05:18 PM   #10 (permalink)
S2kpr's Avatar
Car: 2001 S2000
Mods: Get some
Thank you everyone for the help
Well i tried today to hit the starter with a hemmer and my friend trying to crank it up, but id dosent start when i try to crank it i only hear a click that comes near from the fuse panel... i have to test the other things yet
I hope i can fix it!
Thank you guys!
S2kpr is offline
Old 10-19-2005, 06:10 PM   #11 (permalink)
lude_pwr's Avatar
u did try tapping on the starter WHILE someone was trying to crank the car right? if u did then i test that circuit. locate the fuses and check those out. also find out exactly where that starter solenoid relay is and get your eyes and hands on that sucker. listen for it to click. a quick check is to swap a different nearby relay that is the same in place of the starter relay, if u determine the relay is bad you will obviosly have to replace it. also if u test that circuit, the test light will only light when the ignition is in the crank mode. after tapping on it, if you get a foul smell, that solenoid is definetly locked up. disconnect the battery for the downtime you are about to have if this happens. let us know how it goes, trust me, someone here has to have the right info to throw at u.
lude_pwr is offline
