JRSC is still at full boost at 5000 RPM, while the vortech has less power output as it cubes power through the rev range. I've seen many JRSC civic SI's with nearly the same mods as a few vortech civic SI's. The JRSC wins every time, stop or roll. That's on both the low boost vortech kit which consists of 6 PSI as well as 6 PSI on the JRSC. I've also seen 9 PSI JRSCs run against 9 PSI intercooled vortech SIs, and while it's closer there, the result in the end is still the same. The JRSC pulls away faster and keeps the lead.
Just look at their site:
http://www.vortechsuperchargers.com/...9-00civic.html
and compare:
http://www.jacksonracing.com/Custome...=99civicsi.gif
See how the vortech torque numbers are lower? Remember that horsepower is just a calculation of torque. HP = (TQ x RPM) / 5250. Gearing also plays a part but considering all the SI's are using the same trannies, that negates that argument for this purpose. That leaves tires and driver for the most part.
Vortechs have their place in racing and forced induction characteristics (they work great on S2000's due to their bigger displacement and high rpms, as well as many domestic V8s) but are underpowered and overpriced for any B series. Thats just a simple fact.
Edit: I also love how vortech claims "Increase Horsepower to 277 and torque to 175 ft/lbs" yet their bargraph doesn't even come close to touching 175 ft/lbs of TQ. Not to mention if we were to take the 98 ft/lbs of STOCK tq from the JRSC dyno graph and add the "Adds 64 ft/lbs of torque" they claim for their high boost kit, 98+64=162. BUNK. Makes you wonder what else they are lying about or manipulating.
