swap update
so the swap is going down the sh!++er as does a lot of swaps starting out ive been doing most of the work myself and im not the most handiest around a engine bay but i try the problems have been mostly little but when you add all the small ones up they get pretty big so far we have misplaced some bolts the wiring harness i bought was the wrong the one in my car has been masacered by the idiot who owned it before me and the driver side mounting bracket on the motor has been replaced and it wont bolt up with the hasport mount and also we had to take off the bottom mounting location on the crossmember so the gsr tranny could fit so that is where im at and after spending 10 hours under the hood i think im going to take a break until the mount gets here monday so i can refocus so i do not get to frustrated if i rush i will just make more problems so i might as well take my time to do it right also if any one knows where i can get some userfriendly wiring scematics for the 89 crx si it would be greatly appreciated
on my 14th car and i doubt the madness stops here
