Old 08-07-2008, 09:20 PM   #1 (permalink)
Joewill2848's Avatar
Car: 89 crx si
Mods: 17" wheels cat back exaust black halo headlights black corner lights clear marker lights blck rcing seats 4 point harnesses spoon sports steering wheel blacked out windows strut tower bar skunk2 shift nob complete energy suspension bushing kit energy suspension mtr mnts white face gauges body kit fresh red paint battery discnect swtch lambodoors
Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848
swap update need advice
ok the motor and tranny is in and bolted up the new pressure plate cleared the gsr tranny so that was a relief but one of the axles was wrong so i have to get that tomorrow my problem is the car will turn over but not firing when i turn the key i am not hearing my fuel relay or any other for that matter turn on not sure could be a main power wire that needs to be replaced or ground? very unsure any advice would be appreciated
on my 14th car and i doubt the madness stops here
Joewill2848 is offline
Old 08-08-2008, 03:52 PM   #2 (permalink)
GunMetal Member
hndacvcsi's Avatar
Car: 97 civic dx
Mods: coilovers 3" exhaust, shorty intake, built bottom end, more to come!!!
hndacvcsi Hello down there miniscule peonshndacvcsi Hello down there miniscule peonshndacvcsi Hello down there miniscule peonshndacvcsi Hello down there miniscule peonshndacvcsi Hello down there miniscule peonshndacvcsi Hello down there miniscule peonshndacvcsi Hello down there miniscule peonshndacvcsi Hello down there miniscule peonshndacvcsi Hello down there miniscule peonshndacvcsi Hello down there miniscule peonshndacvcsi Hello down there miniscule peons
check and recheck all your ground wiring, your battery fuse in the engine box, and your main relay under the dash. if anyone of these are bad you will get nothing when trying to start it. sounds to me like a ground. did you mount the tranny ground back on it?
Talk not of loud pipes and which wheels spin, but rather of speed and respect. For when the deed is done, and pride lay wasted on the ground,you will remember the day when you were beaten by the "4-banger"
hndacvcsi is online now
Old 08-09-2008, 08:07 AM   #3 (permalink)
Car: 89 crx si
Tranny ground is on there. Also I have put on a new power wire and hooked it back into the fuse box. I have replaced the main relay and made sure grounds from the radiator, valve cover, and starter are all connected. I am unsure of what else to do at the moment. Also i have plugged the old ecu back in just to make sure but the reaction was exactly the same nothing. So i do not know what to do. For now I am going to give it a break, think and wait for advice.
Old 08-09-2008, 08:12 AM   #4 (permalink)
WVU97GS-R's Avatar
Car: 1989 240sx
did you start another thread about the same swap ?
http://www.superhonda.com/forum/f30/...please-333110/
Originally Posted by HonduhDave View Post
He's not Japanese, he was referring to the languages he can speak. He's capable of speaking English, can probably curse and ask for a beer in Spanish and has heard his girl moan in Japanese in bed
WVU97GS-R is offline
Old 08-09-2008, 01:42 PM   #5 (permalink)
Car: 89 crx si
i have a different thread on another matter of the swap but not this particular problem
Old 08-09-2008, 02:09 PM   #6 (permalink)
WVU97GS-R's Avatar
Car: 1989 240sx
ok i thought it was me hehe
Old 08-10-2008, 01:10 AM   #7 (permalink)
madmaxsmp is on a distinguished road
im having the same problem. 88 si putting a b16a1. did u put power to the fuel pump? i tried that and it made the pump fuel the filter but my injector rail sounded funny. so if yah get that figured out let me no i will do the same. im almost ready for paint just need to finish the motor then sand the primer
madmaxsmp is offline
Old 08-10-2008, 12:49 PM   #8 (permalink)
Car: 89 crx si
i cant hear the relay for the fuel pump but the fuel rail was leaking gas also i have no spark at all but that could be in the distributor (cause you know honda distributors are famous for going out in times like this) so for now we are tracing down wires and have a thought about doing a total rewire if i do i am going ahead and doing a wire tuck also
Old 08-24-2008, 03:20 PM   #9 (permalink)
hey i got mine running it was my thermostat ground it was hard to find i also did a bunch of sanding on stuff now im waiting for rack and tie rod ends and im almost there good luck
Old 08-26-2008, 03:28 PM   #10 (permalink)
Car: 89 crx si
yeah i had a ground missing in the same location I have it running and am driving it daily now i am working out other problems
Old 08-26-2008, 06:46 PM   #11 (permalink)
GunMetal Member
EnJoiThaRex's Avatar
Car: 1988 CRX SI
Mods: D15B2 w/PM6: pacesetter headers, tanabe 2 1/4 exhaust system, ZC tranmission, B&M short shifter, "Custom Shift Linkage", "aftermarket" intake, "8 yr old" tanabe lowering springs
EnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problem
... out other problems
Seems like cars like causing problems more than they like to run smoothly.
RICER -drive it like ya stole it
Technicians -drive like ya built it!!
EnJoiThaRex is offline
Old 08-27-2008, 12:48 AM   #12 (permalink)
drummingpariah's Avatar
Car: 1973 Datsun 240z
Mods: Chevy v8.
drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?
As the saying goes, Hondas run badly longer than most cars run at all.
(they also say that about every other manufacturer...)
build thread (click the picture, stupid):
Play Travian with me, it's free!
http://www.travian.us/?uc=us7_33246 <- play travian with me!
"Before I found these movies, women only made my cry through my penis. Now they make me cry through my eyes."
-Peter Griffin
drummingpariah is offline
» Site Navigation
» Home
 > FAQ
» Other Sites
