what all will i need to do
I have a 89 crx hf lighted down to around 1400 lbs. It has a d16a1 motor head is milled 40 tho and has mild porting done. PG7 ecu stock injectors and a 255lph fuel pump. it came with direct port nitrous (100hp) shot in the car not hooked up all the way. what will i need to do to run that much nitrous safely. called holly and gave them the num on the jet and they said it was a 100hp shot.
If i did use the nitrous and it did stay togeather what do you all think it would run?
