Wheel studs - Honda Forum : Honda and Acura Car Forums
Wheel & Tire Center
Go Back   Honda Forum : Honda and Acura Car Forums > Honda - Vehicles > Honda Vehicle Models > CRX Forum
Old 09-05-2002, 03:51 PM   #1 (permalink)
Car: 1988 Honda Crx SI
Mods: Zc power!!!
eskabaz is an unknown quantity at this point
Wheel studs
Hey does anyone know how to change the wheel studs?
I have the rotors and brakes off the there is medal blocking the stud from coming off?
What do i do?
How do i changes these studs on the front at least!!!
Andre
1988 Crx Si
Zc
See you in my rear view!
eskabaz is offline
Old 09-06-2002, 03:04 AM   #2 (permalink)
Car: '91 Civic Si
supercivic is an unknown quantity at this point
i just had this problem about 2 weeks ago.... the proper way would be to remove the hub and dissasemble the appropriate pieces, but my studs had half the heads worn cuz they were loose so they slid right out, for you i suggest takin a saw to them to get them off (since there's no use for them after you're done).
Now to get them on i just "worked" them on w/a plastic hammer, be careful when you do this so as not to damage the threads. the 1st 1/4 or 1/3 of the stud will go inthe rest will need your help. Taking off the dust shield gives you more space to work in. this is the quicker way to do this, i had it all done in about 45 min to an hour.
supercivic is offline
Old 09-06-2002, 03:25 AM   #3 (permalink)
GunMetal Member
Car: 92 civic hb
Mods: b16a
Stripes777 is an unknown quantity at this point
are the studs the things that the wheel nuts bolt on to? if so , one of my front ones is broken, how much is it to replace? someone told me a hundred bucks, but i think that was wrong. and is it something that is easy to do? thanks
Stripes777 is offline
Old 09-06-2002, 04:34 AM   #4 (permalink)
Car: 99 Dakota 5.9 R/T, 00 VW Jetta GL
Mods: Why would I tell you? haha....
Phatwhippin_CRX is an unknown quantity at this point
yeah, honda sells them for 5 bucks a stud..... realistically, all you have to do is hammer them out the back side of the hub
Member Since '01. Old-Skool, Bitches.
1989 DOHC VTEC CRX Si -Sold!!!
1988 SOHC ZC CRX Si -Scrapped
1999 Dodge Dakota R/T -For Sale
2000 VW Jetta GL -Virgin.... for now
Phatwhippin_CRX is offline
Old 09-06-2002, 02:51 PM   #5 (permalink)
The_Engineer is an unknown quantity at this point
take your hub off and take it to a shop with a press, they should be pressed out and the new ones pressed in, yeah i guess you can do this yourself but make sure you have a big hammer and get them in straight or your wheels will have a problem fitting properly, the shop will have studs there, just make sure that they are the right pitch thread if you have through lugs, see if you can get the studs longer to take advantage of your lugs
The_Engineer is offline
Old 09-06-2002, 05:20 PM   #6 (permalink)
Josh is an unknown quantity at this point
What are the advantages of longer lugs? Assuming you have open end lugnuts...
nerd (nrd)
n. Slang
A person who is accomplished in scientific or technical pursuits but is felt to be socially inept.
Josh is offline
Old 09-06-2002, 07:53 PM   #7 (permalink)
GunMetal Member
Car: 92 civic hb
Mods: b16a
omg 5 bucks, thats cheap, so i jus roll up to honda and tell them i got a 92 hatchback, give them 5 bucks and they'll give me a stud thing>? how much does a shop charge to put one in? u say bring it to a shop, what kind of shop do i bring it to? like does it have a technical name, so i can look it up in the phone book ,thanks
Old 09-07-2002, 07:33 AM   #8 (permalink)
yeah only like 5 bucks i think @ the dealership..... any shop can do it. Hell, you can do it in your backyard, so any shop had BETTER be able to do it!
Old 09-07-2002, 09:56 AM   #9 (permalink)
Mods: Zc power!!!
yeah its easy i just changed mine
just beat them out and sneak them in
hheh!!!
1988 Crx Si
Zc
eskabaz is offline
Old 09-07-2002, 12:06 PM   #10 (permalink)
I just went and bought some at Napa Auto Parts. $2 each. Much better than $5
nerd (nrd)
n. Slang
Josh is offline
Old 09-07-2002, 02:20 PM   #11 (permalink)
GunMetal Member
Car: 92 civic hb
Mods: b16a
good shiznit, imma get one now , peace, btw, how long does it take to change it?
Old 09-09-2002, 01:32 PM   #12 (permalink)
CRX-RX is an unknown quantity at this point
Have any of you actually done this? Or even looked at the manual on how to do this for the front wheels? I have, and according to honda the proper way is to remove the hubs, press out the wheel bearing (which will be destroyed in the process (approx $80)), then remove and replace the stud. A shortcut to this is to remove the dust sheild, grind or cut the bad stud and remove, then grind down one side of the studs seating surface to allow it to pass into the hub without removal of anything aside from the brakes and dust sheild. A full size stud will not pass into the hole without pressing out the wheel bearing.
CRX-RX is offline
Old 09-09-2002, 01:42 PM   #13 (permalink)
GunMetal Member
Car: 92 civic hb
Mods: b16a
can anyone confirm this, because i just bought a stud a couple of days ago, and i was planning to change it out today. damnit, if this is true, wouldnt that be gay huh.
Old 09-09-2002, 02:30 PM   #14 (permalink)
I've done it by hammering it out the back side of the wheel. The dust cover may get in the way so you might have to pry that back. If the stud is snapped (like mine was) then you can tap it out with a hammer and screwdriver. IF it is full length, you MIGHT have to cut it down... then you can hammer a new one back in. I've done it both ways....... not recently, but twice on each side.... and this is how I did it.
Old 09-09-2002, 08:43 PM   #15 (permalink)
Oxygen795 is an unknown quantity at this point
That's an easy job to do...
Oxygen795 is offline
