Hey All
Am having a problem with my prelude. It's a imported jdm into ireland h22a
I noticed recently that it would kinda stutter a bit when puttin the foot down but only for 1/4 to 1/2 a second and would be ok then. about a week after that while i was coming home from work it happened again and about 5 seconds later the engine died totally.
I can turn the key and the engine turns over. But it will not spark at all. I relaced coil at this point but no joy.I noticed that the CEL light is NOT lighting when ignition is turned on,Before it would light for 5-10 seconds and go out with a click.
I Have had new alternator put in within the last 6 months and a timing belt + tensioner done after the old one broke(no damage luckily) about 4 months ago.
Has anyone any ideas as to what Could be wrong
after cranking remove the plugs and see if they are wet with gas.
if not, thats a major problem. clogged filter, bad fuel pump, or a very leaky fuel line.
if its getting gas, go one by one checking for spark with a buddy. test the same cylinders a few times to see if its changing form existing to non-existing, or if its changing from weak to strong.
if it fluctuates, its possibly a bad cap and rotor.
All about the single cam
Originally Posted by My Caramel Chocolate Lover
Mods: Fuzzy dice hanging in the mirror, chrome hub caps, oversized waabaa valves
if your not getting spark then it is most likely your distributor
check all the connections going to it
take your oil cap off and if you can see a cam or rocker arm or something, have someone crank the engine and see if the cams are rotating just to rule out a timing belt problem that could be a result of improper installation
set your timing to 15-20 degrees off to simulate belt slippage. Im sure you can figure it out if you listen. I have sharp hearing. metal on metal is pretty clear.
yall missed something very important. if the cell doesn't light up like it normally does when you first turn the key to start. check the bulb, if the bulb is good if memory serves me correctly it means the ecu is fried. do some more research on it though.
Originally Posted by Darkness
pshh you're obviously new to woman and vaginas....bitches will nag and vagina's will eventually sag.....
it's better to lease in this situation than it is to own
