Emergency Brake Cable? Caliper? Or both? - Honda Forum : Honda and Acura Car Forums
Old 09-06-2011, 06:42 PM   #1 (permalink)
flyinfree is on a distinguished road
We have a 2000 SH type and this morning the emergency brake would not release. By the time I got home this afternoon it was released. I took the rear wheels off to inspect. What I found is that the left rear emergency brake would not engage. I suspected it was the cable even though when we pulled the lever I could see the cable flexing. I removed the pin from the caliper and tried to move the cable. The cable end did not move when disconnected. I then tried to engage the parking brake by putting a pair of pliers around lever on caliper and attempting to move it down as if it had pressure from the cable. This did not engage the brake. So I am led to believe that the cable and the caliper need to be replaced. Do you agree or disagree. Can you engage parking brake by moving caliper lever as the cable would?
My son just told me tonight that the parking brake has not held the car for some time. I guess it is possible that the drivers side has not functioned for some time and it was the passenger side that was locked up this morning. Any feedback would be appreciated.
flyinfree is offline
Old 09-06-2011, 08:12 PM   #2 (permalink)
Iron Monk
MortsAccord's Avatar
Car: 1997 Honda Accord EX
MortsAccord you're still here?MortsAccord you're still here?MortsAccord you're still here?MortsAccord you're still here?MortsAccord you're still here?MortsAccord you're still here?MortsAccord you're still here?MortsAccord you're still here?MortsAccord you're still here?MortsAccord you're still here?MortsAccord you're still here?
The e-brake cable has leverage that you probably can't produce with your hands and a pair of pliers. The caliper is probably working. If its siezed then the rotor will look like a rusty piece of shit.
The e-brake cable.probably needs adjusted. The brake lines could use some new fluid in them im sure.
You can free stuck calipers pretty easily. To free a stuck caliper get the side in question broken down with the caliper removed( only the caliper being off is nessicary). Have a helper slowly press the brake pedal with the car off, while you watch the piston. Don't get too crazy with it, you don't want the piston to pop out. Also, with rear calipers they take a turnback tool or some stupid shit. So even with a nice new caliper its still a PITA to push the caliper back in.
Basicly rinse repeat until the caliper is easy to push in and out. If its really siezed you will need the vaccum boosters assistance.
If the e-brake cable is siezed up, adjusting it super tight, then jerking the e-brake should give it some play. Once it has play you can spray some PB Blaster on the cable where it travels inside the sleeve. This should help completely free it. Then you can get some grease, like disk brake wheel grease.
I gobbed A bunch on my 87 Crx's brake cable and it helped greatly, I just had to pull and release the cable a shitload of times., which started sucking up the grease.
Be careful when trying to.break loose the bleed screws, you don't wanna get one that's a little stuck and break the bleeder offf in the caliper. Spray PB blaster on the bleeders and come back to em in 30 mind and recheck them, if not freed up spray some more and give it some more time.
A set of small wire brushes to clean things up may help. I once sprayed some WD-40 between the rubber boot and the piston before pushing the piston in and out around 20 times.
http://www.angelfire.com/games/marshallmort/Oil.pdf
AWSOME tech articles for FREE, get educated on some REAL information.
currently down.
http://www.bcae1.com
Everything you ever need to know about auto lighting:.
http://www.danielsternlighting.com/tech/tech.html
MortsAccord is offline
Old 09-06-2011, 08:23 PM   #3 (permalink)
The caliper works fine with the brake pedal. I can get enough grip with a large pair of channel locks to move the lever that the cable is connected to. I can only assume the caliper had 2 seperate operating mechanisims one for braking one for the ebrake. I wouldr tink flushing it would flush the main piston operation rather than the ebrake. Can i flush the ebake portion? If so how?
