Go Back   Honda Forum / Acura Forum - SuperHonda.com > Honda - Vehicles > Prelude Forum
Old 11-26-2005, 09:59 AM   #1 (permalink)
Freakin'H22A What did you do to deserve all this rep?Freakin'H22A What did you do to deserve all this rep?Freakin'H22A What did you do to deserve all this rep?Freakin'H22A What did you do to deserve all this rep?Freakin'H22A What did you do to deserve all this rep?Freakin'H22A What did you do to deserve all this rep?Freakin'H22A What did you do to deserve all this rep?Freakin'H22A What did you do to deserve all this rep?Freakin'H22A What did you do to deserve all this rep?Freakin'H22A What did you do to deserve all this rep?Freakin'H22A What did you do to deserve all this rep?
Red face H22A New Koyo Radiator - Fans need bolt modding!!!
I have a '93 Prelude S, which has a '95 JDM H22A swap. I just bought the Koyo Radiator and the fan bolts won't line up I beleive that the Vtec radiators are different from the Si or S radiators. I have a good idea for this mod. I would like some ideas or if you have done this mod please share. :clap
My idea is that since the Radiator stock fan has one upper bolt that lines up, the rest are off position, I figured out that I can bolt a piece of aluminum for the other bolt positions (make aluminum arms) since the bolt pattern with the arms have a good mechanical advantage and it seems that if it the actual bolt that lines up loosens, due to to do the lengthen the arms added will keep it without rotating resulting in a good fitment. If it works alright I'll let you guys know.
I know that it might be hard to explain here, so I'll post pics during this week. For those of you who would like to buy or have encountered the problem already.
Freakin'H22A is offline
Old 11-28-2005, 04:52 PM   #2 (permalink)
Car: Honda Prelude 95' Civic 87'
Mods: rims, music
xavilude is an unknown quantity at this point
make some aluminum clamps or bases... thats what i did, no problems yet
xavilude is offline
Old 11-28-2005, 05:38 PM   #3 (permalink)
Eso hice hoy ... gracias!
Old 11-29-2005, 03:00 AM   #4 (permalink)
Car: 94 Honda Prelude VTIR
Mods: not enough
94vtirozguy is an unknown quantity at this point
why not go to junk yard and find the correct fans for the radiator you bought ???
yes the S and VTIR fans and mounting holes differ.
HONDA - Hold On Not done Accelerating
94vtirozguy is offline
Old 11-29-2005, 11:35 AM   #5 (permalink)
Mods: rims, music
jajaja dale eso esta
xavilude is offline
Old 11-30-2005, 09:09 AM   #6 (permalink)
Car: 1996 Honda Prelude Si
ricecake will become famous soon enough
koyo radiator fan mounts mod
I installed one on my 96 si - has the same fitment problems - you can improvise or you can look into FAL FANS - these bastards are expensive though.
What I did was use one mount on the bottom that sinked up for each fan and then drilled holes in the side of the thin edged sides of the radiator (obviously outside of the actual radiator) with matching holes in the fan housing and put in bolt/lock nut - 2 per side - then on top make custom brackets - from what i could tell that set up was much stronger and fit better than using the top mounts as your starting point for other improvising.
One fan will be easier than the other - and the fan that is on the left if you are facing your engine bay may end up actually rubbing on a primary chassis piece near the base of the motor - I had to actually shave about a half inch off the edge of this fan to stop rubbing.
That was my experience.
ricecake is offline
Old 11-30-2005, 11:12 PM   #7 (permalink)
Car: 95 GBP Lude H22
Mods: JDM H22/M2B4/I/H/TP/E/Koni Yellow/H&R Race/ES Poly Bushings
Weenie Um, 1 million? Damn!Weenie Um, 1 million? Damn!Weenie Um, 1 million? Damn!Weenie Um, 1 million? Damn!Weenie Um, 1 million? Damn!Weenie Um, 1 million? Damn!Weenie Um, 1 million? Damn!Weenie Um, 1 million? Damn!Weenie Um, 1 million? Damn!Weenie Um, 1 million? Damn!Weenie Um, 1 million? Damn!
zip ties
or remove the fans entirely and shut the car off in traffic...they do take about 2 hp to run
To whoever raped my car: you broke my heart, so when I find you I'll put a bullet in yours. I'll set you on fire and piss on your burning corpse you worthless piece of shit. BE AFRAID.
95 Prelude - JDM H22/M2B4/etc etc - Stolen
93 Prelude - FS
Weenie is offline
Old 12-01-2005, 05:14 AM   #8 (permalink)
Originally Posted by Weenie
zip ties
