How do i know if my clutch is slipping??? - Honda Forum : Honda and Acura Car Forums
Wheel & Tire Center
Old 03-04-2003, 03:14 PM   #1 (permalink)
Blaznh22 is a splendid one to beholdBlaznh22 is a splendid one to beholdBlaznh22 is a splendid one to beholdBlaznh22 is a splendid one to beholdBlaznh22 is a splendid one to beholdBlaznh22 is a splendid one to beholdBlaznh22 is a splendid one to behold
i think my car needs a new clutch already, , it only has about 45k miles....people says if ur clutch is slipping then most likely u need a new clucth so my question is how does clutch slipping feels like, what does ur car do when the clutch is slipping?? i have now clue.........
Blaznh22 is offline
Old 03-04-2003, 03:14 PM   #2 (permalink)
Defi4nce has a little shameless behaviour in the past
When the RPMs go up but you dont go anyfaster.
93' Blk Civ Coupe
2.0 LS/VTEC Fully Built
Home____________Kaneohe
"The wicked rule, and the fools follow"
Defi4nce is offline
Old 03-04-2003, 03:24 PM   #3 (permalink)
Car: 99 dc2
Mods: tons
sujinX has a little shameless behaviour in the past
ur in gear u gas .. the rpms go up and ur still crusing like its at 2000 rpm but actually ur like at 6000 or sumin.. i advise u not to drive around nemore with the clutch slipping like that it'll end up costing u a grip.
sujinX is offline
Old 03-04-2003, 03:33 PM   #4 (permalink)
Car: 2000 Accord 5-spd
wonTong is an unknown quantity at this point
back then when i had my 91 integ, the clutch would slip every once in a while.. i'd press the gas, but the car would just rev up to 4k with no power. i didn't realize what it was...
then finally one day the clutch broke while i was driving in the street. i couldn't step on it anymore.. and the gears could move alone.
better it it replaced before it fails on you on the freeway..
wonTong is offline
Old 03-04-2003, 09:21 PM   #5 (permalink)
lOOkatme's Avatar
Car: 99 lude
Mods: too much to list
lOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problem
like people said...you try accelerating...generally at full throttle in a lower gear and the car doesn't engage....it will shoot the rpms up but the car isn't going nearly as fast as the rpms are rising.
also you can smell the clutch generally.
- Mario Andretti
Car for Sale. PM me.
lOOkatme is offline
Old 03-04-2003, 09:26 PM   #6 (permalink)
Shibby H22A's Avatar
Car: 98 Civic Coupe
Mods: stock
Shibby H22A has much to be proud ofShibby H22A has much to be proud ofShibby H22A has much to be proud ofShibby H22A has much to be proud ofShibby H22A has much to be proud ofShibby H22A has much to be proud ofShibby H22A has much to be proud ofShibby H22A has much to be proud ofShibby H22A has much to be proud of
and that smell isnt very pleasant...
SOLD H22A1 95 Civic HB 13.64@102 best 1/4
SOLD 93 Prelude VTEC PICS/SPECS
Shibby H22A is offline
Old 03-04-2003, 09:37 PM   #7 (permalink)
im not having any of that sign at all, its just that the clutch pedals grab farther out then it use to ( i think)...........
Blaznh22 is offline
Old 03-04-2003, 10:18 PM   #8 (permalink)
j0hns0n is an unknown quantity at this point
bleach your clutch
j0hns0n is offline
Old 03-04-2003, 10:19 PM   #9 (permalink)
Originally posted by Blaznh22
....the clutch pedals grab farther out then it use to ( i think)........... [/B]
bleach your clutch
j0hns0n is offline
Old 03-04-2003, 10:21 PM   #10 (permalink)
Originally posted by j0hns0n
bleach your clutch
what do u mean by bleach your clutch?? what is that??? :
Blaznh22 is offline
Old 03-05-2003, 11:09 AM   #11 (permalink)
Car: 2001 Prelude SS
Mods: AEM Intake,Clear Side Markets,Clear Front Bumper Lens,Pro One Exhaust
Hustler904 is an unknown quantity at this point
he means bleed your clutch fluid
Hustler904 is offline
Old 03-05-2003, 03:47 PM   #12 (permalink)
how will that help???
Blaznh22 is offline
Old 03-06-2003, 11:54 AM   #13 (permalink)
Car: 1996 Honda Prelude VTEC
Mods: so many mods you'd puke...
BlueLude is an unknown quantity at this point
Check the fluid in your reservoir and make sure it's full and not really dark (if it's dark change it) - I think bleeding your clutch is kinda like bleeding your breaks, when pressure gets low it helps to build it back up.
I was on the freeway when my clutch failed, I went from about 70mph to 0 in about 50 feet - it locked up the wheels for some reason. Needless to say it was scary as fuck, so I'd suggest changing it soon if it needs it...
1996 Prelude
2.2 VTEC head on 2.3 Si block
BlueLude is offline
Old 03-06-2003, 04:36 PM   #14 (permalink)
so bleeding it will stop my clutch pedal from grabing farther out??? cuzz i dont think my clutch is worn since it only have 45k miles on it just that the clutch pedal grab farther out then it use to and i cant barly chirp 2nd anymore.....
Blaznh22 is offline
