Drove my car yesterday, then all a sudden my oil light start blinking, i shut off da engine inmedietly and add 2 quarts in an the light went away, my qustion is did i harm my engine by running the car with low oil?
and what if you did????? I mean what you going to replace the engine now???
You might have , but I doubt it... It just got below the set pressure. You should be alright if you replaced the oil as soon as you saw it flicker.. I would be more worried about where the oil went,, unless you just neglected it for so long that it used it up.... I've made it a habit to always check my oil when I get fuel.. Just seems right to do it then, and keeps a constance eye on the status of I engine.......
RICE BURNER'S!!!!
Will buy oem 4th gen parts.. What'ch you got?? PM me
Mods: car is stock but with a jdm f22b swap with intake/ header/ muffler and stock in the middle stuff
naw, if it was running fine before and after the light flashed, you should be fine. if it has been a while since you changed it it is probably "normal" Honda oil consumption. if you are up to date on all your oil changes, i would check to see where it is leaking from. every Honda engine i have ever seen with over 50k miles will burn about 1 quart every 3000 miles. once you reach 100k plus miles it may go up to two quarts of oil consumed. my 86 civic had 142k miles and it would go through 2.5 quarts every 3000 miles. my oil light would come on while cornering. that is how i knew when to change my oil when my speedometer cable broke lol. well CHANGE THAT OIL and happy honda days to you.
im almost sure you have a spun bearing. the bearing blocked the oil passage raising the oil pressure causing the blink. low/ no oil pressure is a steady light.
He's not Japanese, he was referring to the languages he can speak. He's capable of speaking English, can probably curse and ask for a beer in Spanish and has heard his girl moan in Japanese in bed
you should check every 3 months. when the last you change your oils?
