Go Back   Honda Forum / Acura Forum - SuperHonda.com > Honda - Vehicles > Prelude Forum
Closed Thread
Old 03-01-2002, 02:20 PM   #1 (permalink)
Ludeboy's Avatar
Mods: NOS sticker, and phat wing.
Ludeboy is an unknown quantity at this point
tech wrench Prelude -FAQ FAQ FAQ- How to's, Discussions, Articles and more!
Everyone is encouraged to submit tech info or how to posts to be added in FAQS as long as it is Prelude specific. If you see a thread you feel belongs in FAQS, please click on the "Report this post to a moderator" button and we will place it here if it is good info.
When Posting questions to the forum be sure to have a clear title , with model / year included, dont worry about using too many words. Most people first sentence inside the post is a perfect subject title. But they use a "Hey how bout this" , blank statements , vague questions like "Intakes" Then you see First line What about AEM Intakes. Topic should have been "AEM Intakes , plus what year and car you have." Incorrect posts might be deleted.
READ THIS IF YOU WANT GOOD RESPONSES FROM YOUR POSTS
-HOW TO-
-HOW TO: 92-96 JDM Power Folding Mirrors
-HOW TO: 92-96 Prelude JDM climate control
-HOW TO: 92-96 Prelude JDM One Piece Headlight Conversion with USDM Harness
-HOW TO: 92-96 Prelude Moonroof Conversion Install Guide
-HOW TO: 97-01 Prelude MSD igntion install + Blaster 2 coil
-HOW TO: Auto to Manual Transmission Conversion
-HOW TO: Lower your seats
-HOW TO: Carbon Clean: Seafoam [restore horsepower]
-HOW TO: Change master and slave cylinders.
-HOW TO: Change your manual transmission fluid.
-HOW TO: Clean and Polish your Exhaust Ports When installing your header.
-HOW TO: Compression Test
-HOW TO: Cure shock knock.
-HOW TO: Degreeing your camshafts for installation
-HOW TO: Euro R intake manifold install
-HOW TO: Flush your motor oil / degunk / clean it [helps smooth idle]
-HOW TO: H22 Auto Tensioner to H23 Manual Tensioner Conversion
-HOW TO: H22A swap into a Prelude Si.
-HOW TO: Install an Aftermarket header.
-HOW TO: Install an Aftermarket Ignition on 4th gen
-HOW TO: Install a CAI
-HOW TO: Install JDM fogs.
-HOW TO: Install a Lightweight battery.
-HOW TO: Install a Short Shift adapter in 4g Prelude.
-HOW TO: Install a genuine S2000 engine start button.
-HOW TO: Install Tanabe Sustec Underbrace for 4g Prelude. Plus Review.
-HOW TO: Install Type-R DC2 Shift Boot , Great for aftermarket shifters
-HOW TO: Legend Twin piston calipers onto 5th gen
-HOW TO: Pull CEL Codes
-HOW TO: Replace Cam Seal
-HOW TO: Replace Clutch Master and Slave Cylinders
-HOW TO: Replace Fuel Filter (4th Gen)
-HOW TO: Replace Oil Cooler Gasket
-HOW TO: Remove silver part of headlight on 5th gen Prelude
-HOW-TO: Remove your big ugly 4th gen Steering Wheel
-HOW TO: SH Shiftboot and aluminum trim rings and speaker grills.
-HOW TO: Tuck engine bay wires
-HOW TO: Quickly Change Manual Transmission fluid & Whats the best oil to use in it.
-HOW TO: Valve adjustments.
-TECH-
Lost Motion Assemblies (LMA's) explained
4th Gen online repair manual
-4th Gen Prelude Online Repair Manual
-4th gen Repair manual in HTML format
-USDM 4th gen prelude 4ws writeup.
PROBLEMS & FIXES
-Car has trouble starting, takes a while
-Emission Inspections 101 : ways to get around the system. Now including California!
-Keep your hand clean, solution tip
DISCUSSION
-Aftermarket Pulleys Discussion
-Are lightweight Flywheels worth it?
-Basic Guide to Motor Modifications
-Best Gas to use in your car.
-Best H22 Header Thread. (find the best header for the h22 motor)
-ECU Fueling 101 -How turbos work.
-OBD2 to OBD1 Conversion
-Turbos vs. Superchargers.
-What exhausts are available for my Lude?
-What puts the motor in Limp Mode?
-What oil are you using: H22 Reliability Poll
-Where can I get a lightweight battery?
-Where can I get stuff CHEAP???
-Where to get genuine Honda parts and accessories for your Prelude.
-Where to buy wheels, wheel weight info, and offset information!
-Where to purchase engines.
SPECIFICATIONS AND GENERAL INFO
-4th gen S, Si and Vtec dyno chart one graph
-Differences between the base model and the Type SH.
-General camber information.
-H22A general information.
-H23 and H22 Valve clearances.
-How does VTEC work?
-How do I post pics?
-The Official H/F series piston/rod/crank/block specs and CR thread
-Prelude engine codes and where to find them.
-Prelude stock specs.
-Spark plug gap
-Wheel weight guide.
Non-tech FAQ
-92-96 Prelude Exhaust pictures and Sound clips
-97-01 Prelude Exhaust pictures and Sound clips
- SHO Members Projector Retrofits
-SHO Member's Rides
SUSPENSION
Lookatme Suspension Theory Thread
Wheel Rim Offsets for 5th Gen prelude!
MEMBER REVIEWS
-Crower Stage 2 camshafts.
-Suspension Techniques sway bars
3RD GEN PRELUDE INFO
Some Info For Modding Your 3rd Gen Prelude
Links to Modifying Your 3rd Gen prelude
EXTRA
Prelude Videos
Top 10 Fastest SHO Preludes:
Top 10 Fastest Superhonda Preludes
06 Pilot 4WD
09 Fit Sport manual
"My daddy gave me a name, and then he walked away." -Everclear
Ludeboy is offline
Old 02-12-2007, 09:46 PM   #2 (permalink)
crdcz03's Avatar
Car: 92Prelude/01S2000
Mods: not stock
crdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peons
Official For Sale Threads
-JUNE: For Sale Thread
-JULY: For Sale Thread
-AUGUST: For Sale Thread
-SEPTEMBER: For Sale Thread
-OCTOBER: For Sale Thread
-NOVEMBER: For Sale Thread
-DECEMBER: For Sale Thread
-JANUARY: For Sale Thread
-MARCH: For Sale Thread
-APRIL: For Sale Thread
-MAY: For Sale Thread
=JULY: For Sale Thread
1992 Honda Prelude VTEC -- 2001 Honda S2000
brittany bluegreen metallic -- silverstone metallic
crdcz03 is offline
Closed Thread
» Site Navigation
» Home
 > FAQ
» Other Sites
