Go Back   Honda Forum / Acura Forum - SuperHonda.com > Honda - Vehicles > Prelude Forum
Old 02-17-2007, 01:08 AM   #1 (permalink)
Car: Prelude (97)
sudhakar is an unknown quantity at this point
SRS dashlight suddenly came on
Hi Guys need help I was driving my 5th lude when suddlenly SRS light just switched on and has remind on since. I swtiched the car off and restarted but the light just constly stays on It is not flashing but just constantly Pls help !!!!
sudhakar is offline
Old 02-17-2007, 09:49 AM   #2 (permalink)
fleming23's Avatar
Car: 97 Prelude
Mods: Header, High Flow Cat, AEM Intake, 18" ADR Spade Wheels, Infinity Reference Componet, Infinity 6x9 rear, Alpine Head Unit
fleming23 will become famous soon enough
This happened to me about a year ago I think. I took it to my honda mechanic and it ended up being a bad cable reel. I don't remember exactly but I think it was 200-300 dollars to have them replace it. I debated just ignoring the light but i decided I would rather have piece of mind that my air bag would deploy if needed.
1997 Prelude
fleming23 is offline
Old 02-17-2007, 09:54 AM   #3 (permalink)
2PhastPrelude is just really nice2PhastPrelude is just really nice2PhastPrelude is just really nice2PhastPrelude is just really nice2PhastPrelude is just really nice
search... theres a way to reset it with just a paper clip.. had to do it before
2PhastPrelude is offline
Old 02-17-2007, 10:33 AM   #4 (permalink)
Car: 97 Honda Prelude
JRamos015 will become famous soon enough
Bring it to Honda...I wouldn't fuck around if I had an SRS light on..that could save a life.
CAR DOMAIN
Ride or die...
~...Born to be hated...~
~...Dying to be loved...~
JRamos015 is offline
Old 02-17-2007, 03:20 PM   #5 (permalink)
it may not be honda told me that a hard bump from a pot hole can cause it
Old 02-17-2007, 04:53 PM   #6 (permalink)
Vertical_Zer0's Avatar
Car: 2000 Prelude base
Mods: None yet :P
Vertical_Zer0 will become famous soon enoughVertical_Zer0 will become famous soon enough
But it may not be worth the risk. It would be a good idea to have it checked anyway; that's a safety issue there.
Check out my last.fm
Vertical_Zer0 is offline
Old 02-17-2007, 06:17 PM   #7 (permalink)
Dooday08's Avatar
Dooday08 has a brilliant futureDooday08 has a brilliant futureDooday08 has a brilliant futureDooday08 has a brilliant futureDooday08 has a brilliant futureDooday08 has a brilliant futureDooday08 has a brilliant futureDooday08 has a brilliant futureDooday08 has a brilliant futureDooday08 has a brilliant futureDooday08 has a brilliant future
Listen to the man!
NOS is like a hot chick with an STD. You know you wanna hit it, but your afraid of the consequences!
"I'm not a fan of facts. Facts can change all the time, but my opinion will never change." - Stephen Colbert
Dooday08 is offline
Old 02-17-2007, 07:21 PM   #8 (permalink)
HondatechAV6's Avatar
Car: 2000 Accord Lx V6
you can read the srs code with a paper clip. this isn't going to hurt anything in the srs system. you can also clear the code using a different procedure. this will save you the 1.0 hour diag. you can then post your code, i'll look it up and you can decide if you want to fix it yourself(if possible) or take it in.
the scs connector is simply a connector that shorts the two wires, so use a paper clip.
I'm just a nice guy.
HondatechAV6 is offline
Old 02-18-2007, 02:32 PM   #9 (permalink)
Car: Prelude (97)
I took my car to Honda dealers this morning but as I taking the car down I decided to use the A/C As soon as I switched the A/C on, the e brake and battery charge light slowly glowed on for about 1/2 second. I switched the a/c off and swtiched on again but the light didn't come on this time. however the SRS light is still on. Lets see what the honda dealers say hope it doesn't cost much
sudhakar is offline
Old 02-18-2007, 03:01 PM   #10 (permalink)
Dooday08's Avatar
Good luck with that.
Dooday08 is offline
Old 02-18-2007, 03:12 PM   #11 (permalink)
Let us know what it was.
CAR DOMAIN
Ride or die...
Old 02-18-2007, 04:36 PM   #12 (permalink)
if that's what happened, i supspect they will say it was code 8-5 and you might need a new battery, maybe even alternator.
Old 02-18-2007, 04:51 PM   #13 (permalink)
Car: Prelude (97)
You know the funny thing is that the car had done only 29,000 km. I bought in 2000 when it had 8,000km and I only use it on fine weekends Iam trying to preserve the last of the prelude
sudhakar is offline
Old 02-19-2007, 03:01 AM   #14 (permalink)
Car: Prelude (97)
Hi guys just to provide you with updates . The dealers hook my car up on the machine and finally found out that my alternator is under charging and its all fried inside When I went to workshop in the afternoon they had it little piceces. They told me I would be better off getting a second hand one as most accords use similar altenator and it will be cheaper . Tomorrow i'll go hunting for second hand one Will keep you guys posted
sudhakar is offline
Old 02-19-2007, 05:44 PM   #15 (permalink)
well, a new one from honda is your best bet- they updated it so the voltage regulator doesn't die out as easily
