Timing Belt Failing Early - Honda Forum : Honda and Acura Car Forums
Old 02-12-2010, 08:54 AM   #1 (permalink)
klwdallas is on a distinguished road
My timing belt has failed early the last two times (93 Prelude VTEC - 223,000 miles). Service interval is 90k. It's failed at about 70k and this time 25k.
I found this thread that sounds similar:
timing belt slipping off cam *help please* - Honda Prelude Forum - Prelude Online.com
This time the mechanic showed be the belt that broke. It was much less than half the normal width. There was also black chewed-up-belt under the cover. (Amazing that it's so overdesigned that it continues to work with such a narrow belt.)
So it's been rubbing against something. Mechanic said he didn't see any marks to indicate rubbing. I assume the rubbing's happening slowly because I don't hear or smell anything.
Last time the belt was replaced with balance shaft belt, water pump, other drive belts, crank seals, cam seals, balance shaft seals.
This time the automatic tensioner was also replaced. I also skipped the water pump because it only had 25k on it. I also had a valve adjustment done this time.
Most of the engine compartment is factory original except for unrelated items like brake slave/master, clutch, radiator, some exhaust, ac hoses, etc.
(By the way, both times the valves were not damaged significantly enough to do anything. One was "slightly bent" the first time, but not replaced. This time they were just checked. The first time it broke when I was starting the car. The second I was going very slow or coasting almost to my driveway. It stumbed and died. Guess I've been lucky.)
Spending about $900 every couple of years is still cheaper than getting another car, but I'd like to understand why this is happening.
Any ideas?
Mechanic said I should come back in a couple months to check the belt, which I agree.
klwdallas is offline
Old 02-12-2010, 12:30 PM   #2 (permalink)
SH Virus
D14A4 Guy's Avatar
Car: 1998 Civic EJ9 D14A4.
Mods: Magnecor leads,Iridium plugs,one-off Stainless exhaust,Sports cat,K&N panel filter,stainless manifold&down pipe,FSE FPR.
D14A4 Guy you're still here?D14A4 Guy you're still here?D14A4 Guy you're still here?D14A4 Guy you're still here?D14A4 Guy you're still here?D14A4 Guy you're still here?D14A4 Guy you're still here?D14A4 Guy you're still here?D14A4 Guy you're still here?D14A4 Guy you're still here?D14A4 Guy you're still here?
Same mechanic did both belt changes?
Somethings out of alignment.
Look down at all the pulleys and see if any stick out, check all guards are fitted correct and spacers/shims are the right way round.
my D14 has a Inner belt guard that has to have the smooth side facing the belt, stuff like that.
DISCLAIMER:
"**This post is a natural product made from recycled electrons. The slight variations in spelling and grammar enhance its individual character and beauty and in no way are to be considered flaws or defects.**"
Because learning is fun
D14A4 Guy is offline
Old 02-12-2010, 02:23 PM   #3 (permalink)
The previous two times--same shop. This time a different shop because I moved. Neither mechanic has seen this before. Previous guy said this latest guy should have found something, but it's probably something he would have missed too, IMO.
