What oil are you running in the transmission.
What oil are you running in your prelude transmission. Im thinking on changing mine out again soon. Want to put something nice / correct in.
how hard is it to change the manual tranny fluid???
what tools do I need to do this??? anything out of the norm besides the regular tools?? I heard I need a long tube for the funnnel....I can pick it up at the hardware store if I need one....just tell me what size to buy!!!
- Mario Andretti
I think its in the faq
Originally posted by lOOkatme how hard is it to change the manual tranny fluid???
its not hard at all...i changed my atf a few times....u jus need one of those containers which a long tube that pumps out the fluid....u jus use that to pump out the transmission fluid then jus get a funnel and add the new fluid
I only use honda MTF but might switch to the Pennzoil Syncromech (GM Syncromesh relabeled and way cheaper) next time. Mine leaks out so quick I dont really care though.
Mods: aem cai, greddy evo, neuspeed/koni's, h&r race, stb, azenis, 4bidden ss, msd wires and flamenco black paint
Piece of cake. 17 and 14mm sockets (at least my 93 requires those two). My funnel tube is 16 inches long and works. Be a little easier if it were a few inches longer. I find it easier to jack up the right side and take off that wheel than getting a really long tube and filling from above. Lets you access the filler bolt more easily too. Takes exactly two quarts. Don't forget to replace the bolt seals.
Originally posted by imp0rted1 i was thinking of changing to synchromesh... any negative thoughts??
That's what I use. If you grind a little, try the synchromesh. If your tranny is fine, get normal MTF and save your money. GM synchromesh is 10 bucks a quart. Find it at any GM dealership. Get the regular kind.
Originally posted by cOiL Piece of cake. 17 and 14mm sockets (at least my 93 requires those two). My funnel tube is 16 inches long and works. Be a little easier if it were a few inches longer. I find it easier to jack up the right side and take off that wheel than getting a really long tube and filling from above. Lets you access the filler bolt more easily too. Takes exactly two quarts. Don't forget to replace the bolt seals.
where is the best place to buy the bolt seals at??? and how much do they run? how many bolt seals....I'll change my fluid over spring break.
How about power steering fluid??? never done that one.....how do you guys do that one? how much, and what fluid does it take?
- Mario Andretti
You can get the same stuff labeled as Pennzoil at most parts stores. Even has a GM part number and costs around $3-5/qt.
Also....all I do is drain my fluid, put the drain bolt back in, lower the car, and fill through the nipple on top of the casing that is a "vent". It is supposed to have a little rubber cap on it, but my JDM tranny didnt have one so the nipple is just sitting there. Its much easier than trying to get a tube into the filler hole.
Originally posted by lOOkatme where is the best place to buy the bolt seals at??? and how much do they run? how many bolt seals....I'll change my fluid over spring break.
you will need 2 plug washer/seal one for the filler plug and one for the drain plug...i got mine at the honda dealer the one for the filler hole are 90 cent and the drain i think are like 5 cent.....
I have Honda MTF in mine, haven't switched to anything synthetic lik royal p or anything. People I know use 10W30 oil...I've yet to see anyone run into problems because of the oil they put in the tranny. They're pretty compatible.
Honda MTF is in mine, never used anything synthetic. I've heard of people using regular motor oil too, but it's supposed to be just a temporary thing until they can get tranny fluid.
