03 Pilot Rear Window Washer Motor
Is anyone aware of a reoccurrence of the Rear Window Window Washer motor failing? Also are you aware that this motor is on the same breaker as the SRS (airbag) system? When the rear window washer motor fails you will know it when your SRS dashboard red indicator light becomes illuminated. I have now had my second motor fail, yet I rarely use this feature. Any insights?? Please reply. Thank you.
