First I would check that you have the proper amount of oil in the crankcase. Next, are you having any problems starting the car? Sometimes the oil light can be related to a faulty battery, alternator, or electrical connection. Finally, was it sitting for a long time? They can sometimes build up a bit of moisture which will flip the oil light.
Just because the codes came back clean doesn't mean that they shouldn't take a closer look at it. If they're not competent at that dealership, try taking it to another nearby honda dealership, or to a competent mechanic.
2005 TSX 6MT + Navi
