» Sponsors
» Sponsors
Go Back   Honda Forum / Acura Forum - SuperHonda.com > Honda - Vehicles > CRV Forum
Old 12-27-2006, 10:40 PM   #1 (permalink)
Zinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sad
Diff between B20b/Z2?
Does a b20 have the same pistons as a b20z and the head is different or does the b20z have domed pistons, or both? Would putting a b18b head on a b20b block make a b20z2? Or do you have to increase the compression more?
Zinc is offline
Old 12-28-2006, 02:25 AM   #2 (permalink)
gurusan's Avatar
gurusan you're still here?gurusan you're still here?gurusan you're still here?gurusan you're still here?gurusan you're still here?gurusan you're still here?gurusan you're still here?gurusan you're still here?gurusan you're still here?gurusan you're still here?gurusan you're still here?
No..it would make a b20b with a b18 head. Pretty much identical to the b20b.
The b20z has different pistons with higher compression...that's it.
uɐsnɹnƃgurusan
Teal Civic Sold: 08/31/2006
FOLD FOR SHO! TEAM 54075
folding@home
gurusan is offline
Old 12-28-2006, 10:08 AM   #3 (permalink)
But the cams are different on a B18b and i've heard that the b20b head flows like a piece! (of shite)
Zinc is offline
Old 12-28-2006, 02:26 PM   #4 (permalink)
gurusan's Avatar
as far as I know..they are identical....there is a very rare b20 head that has vtec sized ports and valves...forgot what that came in though.
uɐsnɹnƃgurusan
folding@home
gurusan is offline
Old 12-28-2006, 04:25 PM   #5 (permalink)
You're right about the pistons but i found out the b20z has the same cams as the b18b, but the cylinder compression between the b20b(us) and the b20z is the exact same! I don't get it. Its gotta be all in the cams! I want to know because i want to turbo a b20 but the b18 takes turbocharging way better and i want to find out why.
Zinc is offline
Old 12-28-2006, 04:27 PM   #6 (permalink)
gurusan's Avatar
nah I'm pretty sure it's the pistons that are responsible for the compression difference. Cams don't affect compression anyway.
uɐsnɹnƃgurusan
folding@home
gurusan is offline
Old 12-28-2006, 04:39 PM   #7 (permalink)
NOOOOO you're lying!!! I can't find that FLIPPING engine anywhere. And actually i don't feel like swapping engines or changing the pistons. HOWEVER i do think putting the b18b head on my b20 will make for a nice turbocharged
Zinc is offline
Old 12-29-2006, 02:58 PM   #8 (permalink)
argenstyle's Avatar
argenstyle is sad...just sadargenstyle is sad...just sadargenstyle is sad...just sadargenstyle is sad...just sadargenstyle is sad...just sadargenstyle is sad...just sadargenstyle is sad...just sadargenstyle is sad...just sadargenstyle is sad...just sadargenstyle is sad...just sadargenstyle is sad...just sad
Don't know if this will help you but here is what I found.
B20B
Found in: Honda CR-V, Honda Orthia
Displacement: 1973
Power: 126hp @ 5500rpm
Torque: 133 ft @ 4200 rpm
Compression: 8.8:1
Bore: 84 mm
Stroke: 89 mm
Redline: 6300 rpm red line
B20Z
NON-VTEC
Found in: 1999-2001 Honda CR-V
Displacement: 1974
Power: 146 hp @ 5500 rpm
Torque: 133@ 4500 rpm
Compression: 9.6:1
Bore: 84 mm
Stroke: 89 mm
Redline: 6700 rpm
Also:
Found this
http://www.google.com/search?hl=en&q...=Google+Search
goto the first or 2nd link
argenstyle is online now
Old 12-31-2006, 04:31 PM   #9 (permalink)
B20B
Displacement: 1973
Compression: 8.8:1
Bore: 84 mm
Stroke: 89 mm
B20Z
NON-VTEC
Displacement: 1974
Compression: 9.6:1
Bore: 84 mm
Stroke: 89 mm
Redline: 6700 rpm
Also:
Found this
Thx the dyno charts really help!
Zinc is offline
Old 01-05-2007, 07:04 PM   #10 (permalink)
Sirfallsalot243's Avatar
Car: 1998 Nissan 240sx SE
To start things off, the B18B and B20 (B and Z) have IDENTICAL heads. There are NO differences at all. The only head that is different is the ultra rare JDM P8R head, with slightly larger ports. Putting a B18B head on a B20 block will only be a waste of time. The castings are exactly the same.
Secondly, the thing that makes the compression higher in the B20Z is the pistons. The Z has domed pistons, and the B has flat pistons. The problem here is identifying which motor is which. This task is easily done if the motor is USDM. A USDM B20Z is marked as such: B20Z. However, the JDM B20 motors are all marked B20B, whether higher compression or lower compression. The only reliable way to check which motor is which, is to look on the back of the block. The higher compression B20B will have a knock sensor on the back, while the lower compression motor will not. The higher compression motor is from 1999+, so if you know what year your motor is for sure, that is an easy way to tell. 1996-1998 = B20B, 1999+ = B20Z.
Finally, I saw someone talked about boosting a B20. Id reccommend otherwise. Had you researched, you would know that the B20 is essentially a bored out B18B, with some minor differences. This means that, because it has been bored from 81 to 84mm, it has cylinder walls that are 3mm thinner than a B18B. This makes the cylinder walls much weaker, and under boost- they will crack. Ive seen B20's boosted before, and make great power- but Im willing to bet they didnt last longer than 20k miles. If you absolutly want to boost a B20, have it sleeved- or run around 6psi or less on it. Like I said, the B18B head is the same as the B20, so swapping it will make boosting it no better or worse.
Oh, and you will want to swap out the stock B20 intake manifold for a B18B one. These ARE different, and the B20 one is crap. Toss it in the garbage.
Sirfallsalot243 is offline
Old 01-06-2007, 10:02 AM   #11 (permalink)
Car: 98 CR-V LX
Mods: Audio: Kenwood speakers, Music Keg, and reciever, 2 10" subs, and two amps; Engine: Comptech Ice Box cold air intake. More to come soon...
Slade is an unknown quantity at this point
b20b and b20z have completely different intake manifolds as well. Not that it matters cause like said above, swaping either out would be for the better.
bucket
Slade is offline
Old 01-06-2007, 04:12 PM   #12 (permalink)
I was going to mention this, but I wasnt 100% sure. Correct me if im wrong: The B20Z has the taller "giraffe" style intake manifold, and the B20B has the lower one, correct?
Old 01-06-2007, 06:26 PM   #13 (permalink)
promotion will become famous soon enough
that is correct. in the olden days we called that a tunnel ram intake manifold. It produces more torque than a short runner manifold. Also, from what I understand, the B18 manifold on a b20 will increase power in the upper rpm range while reducing a little in the lower rpm range
promotion is offline
Old 01-06-2007, 09:21 PM   #14 (permalink)
Ive heard that the B18 intake manifold is superior in every way to the B20 one, simply because it flows so much better. While the B20 one does have longer runners, its innefficient flow characteristics make it inferior to the LS. Just what ive heard.
Old 01-09-2007, 12:48 AM   #15 (permalink)
The b20b has the long intake runners for low rpm torque
the b20z has shorter ones with a little box on top i forget what its called anyways its for midrange torque. Someone posted dyno tests showing all the differences with b20 b18 and b20z. He switched intake manifolds and the b18 intake manifold is much better. ALSO the cams on a b18 and a b20z (not the b20b) are the same. I guess its for higher peak torque.
Zinc is offline
