there might be a loose, worn, or contaminated pump belt; worn pump bearings; fluid restriction, or defective pump or steering gear; try to check those things and inform us what other things did you notice.. It happened to my brother's car before, after thorough examination of all his
honda crv parts it turned out that it has a low fluid level and filling pump reservoir with proper fluid, fixes the problem.. good luck
